trickedcarbine Posted October 25, 2016 Report Share Posted October 25, 2016 25 is lean. Be careful with the starting fluid. Quote Link to comment Share on other sites More sharing options...
arena314 Posted October 25, 2016 Author Report Share Posted October 25, 2016 is that why it won't start then? Sent from my SM-G935T using Tapatalk Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted October 25, 2016 Report Share Posted October 25, 2016 Is your choke plunger assembly in good shape? Did you ever check your bowls? I run 25's with Toomeys and no lid 1 Quote Link to comment Share on other sites More sharing options...
ginger Posted October 25, 2016 Report Share Posted October 25, 2016 what yo run might not be what he needs, being that his altitude or weather is different. Quote Link to comment Share on other sites More sharing options...
J-Madd Posted October 25, 2016 Report Share Posted October 25, 2016 Is your choke plunger assembly in good shape? Did you ever check your bowls? I run 25's with Toomeys and no lid Same here. It's hard to start cold, but runs fine. Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted October 25, 2016 Report Share Posted October 25, 2016 what yo run might not be what he needs, being that his altitude or weather is different. I realize that, I'm just sayin'. But my bike starts when cold just fine with a little choke. Quote Link to comment Share on other sites More sharing options...
arena314 Posted October 25, 2016 Author Report Share Posted October 25, 2016 the choke tube in the middle is just a piece of hose someone cut and uses it slides on pretty easily idk if that can cause an issue or not. and idk if the bowls are on correctly or not. what's the way to tell? Sent from my SM-G935T using Tapatalk Quote Link to comment Share on other sites More sharing options...
ginger Posted October 25, 2016 Report Share Posted October 25, 2016 there is a picture on the first page that shows how to tell the bowls. Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted October 25, 2016 Report Share Posted October 25, 2016 See post #8 in this thread Quote Link to comment Share on other sites More sharing options...
arena314 Posted October 25, 2016 Author Report Share Posted October 25, 2016 neither one of my bowls has that marking on it Sent from my SM-G935T using Tapatalk Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted October 25, 2016 Report Share Posted October 25, 2016 neither one of my bowls has that marking on it Sent from my SM-G935T using Tapatalk Hmmm Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted October 25, 2016 Report Share Posted October 25, 2016 really old ones don't, or you have 2 right bowls. Pull the left bowl and look for a small jet/ passage in it. Quote Link to comment Share on other sites More sharing options...
arena314 Posted October 25, 2016 Author Report Share Posted October 25, 2016 I know one of them has one of those jet passages your talking about I just don't remember what carb it's on you said it should be the left carb? Sent from my SM-G935T using Tapatalk Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted October 25, 2016 Report Share Posted October 25, 2016 I know one of them has one of those jet passages your talking about I just don't remember what carb it's on you said it should be the left carb? Sent from my SM-G935T using Tapatalk Yep, the one with the choke knob Quote Link to comment Share on other sites More sharing options...
arena314 Posted October 25, 2016 Author Report Share Posted October 25, 2016 ok I'll have to look at that tomorrow since I'm working right now. if it's on the wrong carb will it cause the symptoms I'm having? Sent from my SM-G935T using Tapatalk Quote Link to comment Share on other sites More sharing options...
