Gemeiner Posted November 2, 2016 Author Report Share Posted November 2, 2016 So my motors at FAST right now getting started. Couple things i need advice on. 1. They dont recommend a lockup for trails because they said it can keep me from shifting. They said itd be fine with a heavy clutch springs for now. I might wait till i have money to do a lockup if its a good idea. 2. Theyre not sure if i should get the dune port right now since i have stock carbs, and pro circuit pipes. i heard itd be okay with that but if i need to upgrade ill try to squeeze it in. They recommend pods too which i want anyways so ill be looking. Sent from my SM-N920V using Tapatalk Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted November 2, 2016 Report Share Posted November 2, 2016 Get it ported now while it's apart. You can always bolt on different carbs and pipes later. As far as the lock up, probably not totally needed yet. Definitely look in to getting the transmission done though. 1 Quote Link to comment Share on other sites More sharing options...
Gemeiner Posted November 2, 2016 Author Report Share Posted November 2, 2016 I obviously dont want to stay stock im just trying not to bankrupt myself on this build haha ill be spending like 15% my annual wage. If the carbs and pipes are okay for now ill wait a bit Sent from my SM-N920V using Tapatalk Quote Link to comment Share on other sites More sharing options...
Gemeiner Posted November 2, 2016 Author Report Share Posted November 2, 2016 (edited) Get it ported now while it's apart. You can always bolt on different carbs and pipes later. As far as the lock up, probably not totally needed yet. Definitely look in to getting the transmission done though. Im getting the promod done and all the shifter mods but they said for the lockup id need an override tranny. But since its not a drag bike they dont recommend it. Theyre also recommending the straight cut gears. Not sure what the benefit of those are Sent from my SM-N920V using Tapatalk Edited November 2, 2016 by Gemeiner Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted November 2, 2016 Report Share Posted November 2, 2016 You do not need an override to run a lock up. 1 Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted November 2, 2016 Report Share Posted November 2, 2016 Straight cuts aren't needed till you start knocking on the 100+ hp. Quote Link to comment Share on other sites More sharing options...
Gemeiner Posted November 2, 2016 Author Report Share Posted November 2, 2016 Straight cuts aren't needed till you start knocking on the 100+ hp.Perfect thanks. Ill wait on that. Probably put the money into carbs instead. Sent from my SM-N920V using Tapatalk Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted November 2, 2016 Report Share Posted November 2, 2016 (edited) So my motors at FAST right now getting started. Couple things i need advice on. 1. They dont recommend a lockup for trails because they said it can keep me from shifting. They said itd be fine with a heavy clutch springs for now. I might wait till i have money to do a lockup if its a good idea. 2. Theyre not sure if i should get the dune port right now since i have stock carbs, and pro circuit pipes. i heard itd be okay with that but if i need to upgrade ill try to squeeze it in. They recommend pods too which i want anyways so ill be looking. Sent from my SM-N920V using Tapatalk What set up did you end up going with ? Sent from my iPhone using Tapatalk Edited November 2, 2016 by Ayesully810 Quote Link to comment Share on other sites More sharing options...
Gemeiner Posted November 2, 2016 Author Report Share Posted November 2, 2016 (edited) What set up did you end up going with ? Sent from my iPhone using Tapatalk 421 serval dune ported with 22cc domes and coolhead to run 91 at 4000 feet. Vforce 4sChariot ultra water pump Stock carbs right now Airbox no lid Pro circuit pipes for now Promod transmission, ez shift mod, modded star and modded shift arm Billet basket and FAST clutch with heavy springs. Probably wont do a lockup until i pay this off. As long as it holds up. Might need carbs. For trail riding what size carbs do you think id need to not lose throttle response? Sent from my SM-N920V using Tapatalk Edited November 2, 2016 by Gemeiner Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted November 2, 2016 Report Share Posted November 2, 2016 Yeah some new carbs and pipes and ur looking at some great gains. Good luck Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Gemeiner Posted November 2, 2016 Author Report Share Posted November 2, 2016 Think like 33 or 35s? Sent from my SM-N920V using Tapatalk Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted November 2, 2016 Report Share Posted November 2, 2016 28mm or 33mm PWK's if it's tight twisty stuff. If you get wide open a lot, some 35mm pwk's. 1 Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted November 3, 2016 Report Share Posted November 3, 2016 So my motors at FAST right now getting started. Couple things i need advice on. 1. They dont recommend a lockup for trails because they said it can keep me from shifting. They said itd be fine with a heavy clutch springs for now. I might wait till i have money to do a lockup if its a good idea. 2. Theyre not sure if i should get the dune port right now since i have stock carbs, and pro circuit pipes. i heard itd be okay with that but if i need to upgrade ill try to squeeze it in. They recommend pods too which i want anyways so ill be looking. Sent from my SM-N920V using Tapatalk Shit, i didnt know i had problem shifting with a lockup until FAST said it... That's bullshit, me and plenty other peeps are using lockup in trail with 80+ hp bike. You saw my videos, it shift pretty good. Quote Link to comment Share on other sites More sharing options...
Gemeiner Posted November 3, 2016 Author Report Share Posted November 3, 2016 Shit, i didnt know i had problem shifting with a lockup until FAST said it... That's bullshit, me and plenty other peeps are using lockup in trail with 80+ hp bike. You saw my videos, it shift pretty good. Hahaha Ya i dont know what to believe. I trust you guys. Honestly ill have to wait on it. They said itll work with the heavy springs so when i get money ill put one on. Since its so easy to do yourself. They also said 35 pwks which im pretty sure has less throttle response. So ill look for 33s. Sent from my SM-N920V using Tapatalk Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted November 3, 2016 Report Share Posted November 3, 2016 Hahaha Ya i dont know what to believe. I trust you guys. Honestly ill have to wait on it. They said itll work with the heavy springs so when i get money ill put one on. Since its so easy to do yourself. They also said 35 pwks which im pretty sure has less throttle response. So ill look for 33s. Sent from my SM-N920V using Tapatalk No problem dude. You will be the juge when you will try. Quote Link to comment Share on other sites More sharing options...
