ginger Posted September 23, 2016 Report Share Posted September 23, 2016 are you sure its actually loosing performance, and not that you are getting used to it from riding that long? Quote Link to comment Share on other sites More sharing options...
maggdog Posted September 23, 2016 Author Report Share Posted September 23, 2016 are you sure its actually loosing performance, and not that you are getting used to it from riding that long?Yes. Loosing performance because in long riding the throttle response not are the same in short riding compare to long and compare to other bikes that the response are the that same in long or short ride My shee in long ride is very hard to get a top end Sent from my SM-A500Y using Tapatalk Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted September 23, 2016 Report Share Posted September 23, 2016 Well sorry my english yes i'm not from u.s Sent from my SM-A500Y using Tapatalk Well then that makes sense. That said, I've read shit just like you typed that were born and raised here, so you actually did a pretty decent job! 2 Quote Link to comment Share on other sites More sharing options...
maggdog Posted September 23, 2016 Author Report Share Posted September 23, 2016 Well then that makes sense. That said, I've read shit just like you typed that were born and raised here, so you actually did a pretty decent job!Thanks buddy Sent from my SM-A500Y using Tapatalk Quote Link to comment Share on other sites More sharing options...
maggdog Posted September 26, 2016 Author Report Share Posted September 26, 2016 thanks dudes. Yes. Is a overheating issue. Time to get a new radiator I didn't change the radiator before because i didn't know that the radiator give this problem. I was thinking on a carb o electrical problems Quote Link to comment Share on other sites More sharing options...
RIPPIN' IT UP Posted September 26, 2016 Report Share Posted September 26, 2016 Is the radiator the cause of overheating? Sent from my ZTE T84 using Tapatalk Quote Link to comment Share on other sites More sharing options...
maggdog Posted September 26, 2016 Author Report Share Posted September 26, 2016 (edited) Is the radiator the cause of overheating? Sent from my ZTE T84 using Tapatalk yes. and the condition not is 100% has some hits. but the radiator don't leak. thats why I didn't think that cause the problem. but the capacity of coolant not are the same compared to factory. for the hit the radiator has. impeller and impeller gear i checked and is pretty right, hoses are good. Edited September 26, 2016 by maggdog Quote Link to comment Share on other sites More sharing options...
RIPPIN' IT UP Posted September 26, 2016 Report Share Posted September 26, 2016 There can be other causes to the overheating, like intake or compression leaks. Capacity of coolant does play a part in cooling, what is more important is the ability to get rid of that heat. Sent from my ZTE T84 using Tapatalk Quote Link to comment Share on other sites More sharing options...
maggdog Posted September 26, 2016 Author Report Share Posted September 26, 2016 There can be other causes to the overheating, like intake or compression leaks. Capacity of coolant does play a part in cooling, what is more important is the ability to get rid of that heat. Sent from my ZTE T84 using Tapatalk Well, i did a leak down. Don't find a leak But now a guy take off the head and he noticed that pistons is a little bit short to original size (height). has a little space to top. No has a complete stroke and correct compression. I don't know if this affect but anyways i'll change that Another thing to change. And this is the some things that is come when i bought it Sent from my SM-A500Y using Tapatalk Quote Link to comment Share on other sites More sharing options...
maggdog Posted September 26, 2016 Author Report Share Posted September 26, 2016 Well, i did a leak down. Don't find a leak But now a guy take off the head and he noticed that pistons is a little bit short to original size (height). has a little space to top. No has a complete stroke and correct compression. I don't know if this affect but anyways i'll change that Another thing to change. And this is the some things that is come when i bought it Sent from my SM-A500Y using Tapatalk I know affects powerband but i don't know if this cause a overheat Sent from my SM-A500Y using Tapatalk Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted September 26, 2016 Report Share Posted September 26, 2016 Try n explain this part a lil better Quote Link to comment Share on other sites More sharing options...
ginger Posted September 26, 2016 Report Share Posted September 26, 2016 do you have a billet water pump impeller or the factory plastic? i have seen the plastic spin on the shaft even though it looks good. Quote Link to comment Share on other sites More sharing options...
maggdog Posted September 26, 2016 Author Report Share Posted September 26, 2016 Try n explain this part a lil betterWhat part? Sent from my SM-A500Y using Tapatalk Quote Link to comment Share on other sites More sharing options...
maggdog Posted September 26, 2016 Author Report Share Posted September 26, 2016 do you have a billet water pump impeller or the factory plastic? i have seen the plastic spin on the shaft even though it looks good.Factory plastic. Lol that sound funny but really happen i keep in mind Sent from my SM-A500Y using Tapatalk Quote Link to comment Share on other sites More sharing options...
