Jaypatrick Posted September 14, 2016 Report Share Posted September 14, 2016 Hey guys. Looking for a little help. I got coolant leaking from the bottom of my 2000 banshee. Its coming from the hole that the one vent tube goes through but its not coming from the vent. I didnt think anything connected with that hole l. Only to alow the vent tube to go through. Its a pretty constant drip and gets alittle worse when i pop the cap. Cold engine, warm engine it dont matter. Just a steady drip not sure how worried i should be. Sent from my SM-G930P using Tapatalk Quote Link to comment Share on other sites More sharing options...
Jaypatrick Posted September 14, 2016 Author Report Share Posted September 14, 2016 Just noticed that with it turned on its side, the dripping stopped. Sent from my SM-G930P using Tapatalk Quote Link to comment Share on other sites More sharing options...
bigweav81 Posted September 15, 2016 Report Share Posted September 15, 2016 Maybe throw up some better pics? Sent from my SM-S820L using Tapatalk Quote Link to comment Share on other sites More sharing options...
RIPPIN' IT UP Posted September 15, 2016 Report Share Posted September 15, 2016 Are you referring to the tell tale hole in the middle of the pic? Sent from my ZTE T84 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Power_Man Posted September 15, 2016 Report Share Posted September 15, 2016 I'm thinking it coming from water pump? Pull off the plastic water pump cover and check under it. Under the plastic cover is a metal water pump cover that may need resealing. Or I could be out to lunch. Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted September 16, 2016 Report Share Posted September 16, 2016 Have you had the clutch cover off recently? If so, the o-ring on the tube is probably torn. Quote Link to comment Share on other sites More sharing options...
Jaypatrick Posted September 18, 2016 Author Report Share Posted September 18, 2016 Yeah it was the o ring Sent from my SM-G930P using Tapatalk Quote Link to comment Share on other sites More sharing options...
