webbug Posted December 5, 2003 Report Share Posted December 5, 2003 I refill it everytime I go for a ride and at the end of the day the coolent level is below the low range level! So far my banshee is 100% stock. A guy told me its heating problem and the solution is putting aftermarket head, is that true? which heads are better the one part or the one that comes into two parts? Thanks Quote Link to comment Share on other sites More sharing options...
fixitrod Posted December 5, 2003 Report Share Posted December 5, 2003 Try this Click Here It was the best thing I did for my cooling system. Never had an empty bottle again. It's free and it works great. Moving it up front really will help your troble. Quote Link to comment Share on other sites More sharing options...
BenBB Posted December 5, 2003 Report Share Posted December 5, 2003 Look Here Draining the overflow bottle is pretty normal, what's important is to see that your actual radiator isn't low on coolant. If not, relocate or remove the coolant bottle and problem solved. Quote Link to comment Share on other sites More sharing options...
2004LEBanshee Posted December 5, 2003 Report Share Posted December 5, 2003 So is it possible for your radiator to be low and your coolant bottle to be full? Quote Link to comment Share on other sites More sharing options...
fixitrod Posted December 5, 2003 Report Share Posted December 5, 2003 Anything's possible, but if the caps good and the overflow line isn't clog it shouldn't happen. It pulls coolant from the overflow bottle when it needs it. Quote Link to comment Share on other sites More sharing options...
