What port are on these heads
You would be well ahead selling those, and buying some good used cylinders. Send them to sleeper06, and tell him what you want.
Out of curiosity, what did you pay for them?
Sent from my SM-S820L using Tapatalk
i got them on a trade my dmc exhaust for two 4 mil cranks needs rebuild which I can do and the cylinders with Pistons
You said cranks need rebuilt right? Stock to 4mil isn't to bad of prices new compared to rebuilding.
The cylinders will require additional money to get set up correctly.....head, and domes.
Good used cylinders 150-200$. Hell you can even find a set ported for not much more.
That's just my opinion. If you got what you wanted then ok.
I have the parts for the crank so that was good and I understand for the cylinders but the dmc exhaust I only paid 200$ I think I came out but those cylinders will need much work done to them like you said
huh I'm talking about ports, I've still got to learn, I can measure bore, I don't get what your trying to point out
In the above post you mentioned that you can rebuild cranks. I find it laughable that you cannot measure out the cylds, have seemingly few clues, but yet are stating that you can rebuild a crank. Carry on.
You have to start somewhere and I started at the bottom end, which is the crank for your knowledge, but it's called learning which I'm still in the process of doing everyday, come on you flee gotta be a little quicker than that
Flea........noted
Happy trails in your attempt to rebuild the crank. Be sure to spin balance it when you're done! That's VERY important on the banshees!
Sent from my SAMSUNG-SM-G891A using Tapatalk
