Electrical issues...
Rage_kage
I'm having some problems with my electrical system I think, if I push the throttle smooth and slow it will fire on both cylinders, if I stab the throttle the left cylinder cuts out and the right side screams.
Starts fine, idles fine, rev's in neutral fine
I synced my carbs properly.
Pickup gap is set at .15
My electrical readings where:
Stator
17.7 ohms - ignition coil
115.3 ohms - pickup coil
.40 ohms - lighting coil
Coil
.50 ohms - primary
25500 ohms - secondary
Specs from hq page
Stator
13.7-20.5 ohms - ignition coil
94-140 ohms pickup coil
.26-3.8 - lighting coil
Coil
.28-.38 ohms - primary coil
4700-7100 ohms - secondary coil
Changed the coil and the problem is still present, I was hoping someone would recognize this problem and maybe point me in the right direction weather it's a cdi going out, stator failing under load, bad pickup coil
Sent from my phone
Edited by Rage_kage
  • Like 1
I see no mention of plugs, have you tried new plugs?
Sent from my ZTE T84 using Tapatalk
I should take stock in NGK, so far I've changed them 10+ times this summer before every race, and mid race if I end up sucking water at a creek section...
Sent from my phone
Sent from my phone
When you say sucking water, do you get water in your intake?
  • 2 months later...
If you swapped plugs and wires and problem stays on the left side, you don't have an electrical problem, you have an air leak or carb issue.
I would check air screw setting on both carbs and pull pilot jet and check it.  Seen it many times where a tiny ass hair is stuck in the jet causing a slight lean condition.
Brandon
Mull Engineering
