Slickgib Posted August 16, 2016 Report Share Posted August 16, 2016 I'm putting my bottoms end back together and I can't seem to get the square key to sit and slide the gear onto it . Any advice ? Quote Link to comment Share on other sites More sharing options...
Tedder Posted August 16, 2016 Report Share Posted August 16, 2016 It's not that uncommon of a problem. I carefully work one side of the key on a good file. Quote Link to comment Share on other sites More sharing options...
Slickgib Posted August 16, 2016 Author Report Share Posted August 16, 2016 Thank you. I didn't know if i did something wrong Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted August 16, 2016 Report Share Posted August 16, 2016 Only time I have a lil issue is with straight cut primaries Quote Link to comment Share on other sites More sharing options...
Tedder Posted August 16, 2016 Report Share Posted August 16, 2016 Only time I have a lil issue is with straight cut primaries I agree. A mix of straight cuts and Hot Rod cranks are all I've ever had trouble with. Usually working off a couple of thousands or so is all it takes. Quote Link to comment Share on other sites More sharing options...
