sleeper06 Posted August 5, 2016 Report Posted August 5, 2016 I run a parts unlimited boot with the wire clamps, I order them from fast racing 20 at a time. Every bike I work on needs them . I built close to 15 bikes year and one coil out of all of them didn't need boots Quote
sleeper06 Posted August 5, 2016 Report Posted August 5, 2016 Take ohm meter put one lead where spark plug goes, one in the screw end that touches the wire, you should get same reading as if you touched the two leads together . If you get a reading cap is going bad Quote
sheerider11 Posted August 5, 2016 Report Posted August 5, 2016 I run a parts unlimited boot with the wire clamps, I order them from fast racing 20 at a time. Every bike I work on needs them . I built close to 15 bikes year and one coil out of all of them didn't need bootsNology!!!! Quote
sleeper06 Posted August 6, 2016 Report Posted August 6, 2016 I also do like nology, easier starts and I feel a difference in low and mid power while putting around Quote
turbosrt4 Posted August 6, 2016 Author Report Posted August 6, 2016 Get them from fast ?and i check the boots i can never get a solid steady reading at all two sets of caps all the same Quote
turbosrt4 Posted August 6, 2016 Author Report Posted August 6, 2016 Ok checked caps 4.8 and the other 5.1 Quote
sleeper06 Posted August 8, 2016 Report Posted August 8, 2016 Your tester leads could be a lil funky, touch lead to lead and see what number pops up Quote
turbosrt4 Posted September 12, 2016 Author Report Posted September 12, 2016 got a new cdi still hard to start when warm acts flooded if i crack the throttle starts good ,i just dont get it Quote
turbosrt4 Posted September 12, 2016 Author Report Posted September 12, 2016 ordered a carb too' to check floats would that cause starting issues if there wrong like flooding? Quote
ClaudeMachining Posted September 12, 2016 Report Posted September 12, 2016 Will check mine too...I just checked on FAST site, what part do you order exactly Sleeper06? Quote
turbosrt4 Posted April 17, 2017 Author Report Posted April 17, 2017 well i guess its just the nature of the beast>service manuel even says to start a warm motor to open throttle Quote
