Arcing on the flywheel
Seen pics of them weld them selves to the snout and pull out some nice chunks.
As far as why? I'm not sure I luckily have never personally had an issue.
I think it's from not lapping the flywheel to the crank and it arcs. But hopefully someone smarter theN me has a proven answer
I'll give mull a call and pick his brain
Sent from my phone
Wonder if it has to do with his whole grounding write up.
But since I read that, I run a ground from engine to chassis. Might help, might not. But it doesn't hurt.
My nology hot wires also have ground straps to the head.
I went to walmart and got a lawn mower starter cable. Was like 8 bucks, I think like 2 or 4 gauge with 2 nice eyelets.
Rob , I use locktite on all yours so u shouldn't see it . I believe electrolysis is the term your looking for . The flywheel creates a magnetic field
Yup that. Good, I hope to never have to open it.
But regardless, ground strap FTW!!! Cylinder base nut to engine mount on frame
Sent from my SAMSUNG-SM-G890A using Tapatalk
  • Like 1
All grounds already go back to the same black wire. It's not like a car with a battery.
I stand by my stance that zero grounds are needed. No need to sand your pc or oven worry about the coil being grounded.
  • Like 1
