Derrickc14 Posted July 24, 2016 Report Posted July 24, 2016 Hi guys! I'm selling my 2000 banshee with Title <<. It has only 4 to 5hrs on motor and I'm over estimating. Jeff at F.A.S.T. built this motor for me last april. Complete tare down. It was a ground up build on the whole bike. The only thing original on it is the steering stem, brake calipers and rear axle. Everything else is new. I'm going to be getting into the side by sides. I have over 8k in this bike easy. I have most recepts for everything on bike beside my swing arm built by Matt swartz and wiring harness from cody. Im asking for 6500 firm. Bike comes with skat trac Dominators paddles which cost me 460 shipped and a brandnew 5gal vpc12. Plus 26cc domes and oring kit incase you want to drop the compression back to 150psi. It currently has 170psi with 24cc domes. -421 4mill serval built by F.A.S.T. case port matching. Clean cases no wack -Blue anodized F.A.S.T. coolhead with 24cc domes-170psi / extra 26cc domes for 150psi -vforce 4 reeds -adjustable timing plate set at +5 -heavy duty flywheel from F.A.S.T. -200 watt stator -new wiring harness -35pwks 155mains ,CEL 4th clip, 52pilots -New version of the F.A.S.T. oversized bullet fuel bowls -easy springs for the throttle cables from F.A.S.T. -new shift forks -shift shaft and $hift star mods from Fast -billet high flow water impeller -over size radiator with engine ice -shearers smallbore inframes- MINT -brand new never 6in k&n pod filters -polly case saver -F.A.S.T clutch -billet clutch basket with new pressure plates -gear saver 80w in trans -Magnetic drain plug -blue radiator hoses -blue anodized dip stick and parking brake block off -blue anodized asv f3 levers -gold protaper bars -+6 swingarm with spider design carrier holder and JJandA blue anodized carrier -works duel rate front shocks -revalved and heavy duty spring rear shock 220 rider -trail tech l.e.d. head lights highbeam only -jds customs black powerdercoated sprocket and rotor guard -jds customs tribal grab bar powdercoated black -alba front bumper black -black powerdercoated frame *title!! -new chain guides -alba racing +1 +2 A arms and heavy duty tie rods -20/11/8 ambush cut rear tires and tusk front tires. Like new + dominator paddle like new - new D.I.D chain gold and black sprockets. Stock size 14-41 -New rear master cylinder -Black Gator skin seat with yamaha blue stitching from vegas jeff -gas as of now with the timing at +5 and 170psi/24cc domes i run straight vpc12 with benol 32:1. I dont know if I forgot anything. Like I said its practically brandnew from the ground up. On my motor build sheet you can see the date on when it was built. One year old. I have pictures of the whole build from bare frame and swing to all the way complete in steps. Pm for pictures + recepts and I'll send them to your cell. Quote
guns4children Posted July 24, 2016 Report Posted July 24, 2016 I'm not interested in buying but I would love to see it. Next time you're taking a dump upload those pics to photobucket and post image links here. Quote
special06shee Posted July 24, 2016 Report Posted July 24, 2016 If you wanna sell your dominators separate id possible be interested. Side note, have we ever met? I see you had matt build your swinger.. Quote
PaymentPlan Posted July 24, 2016 Report Posted July 24, 2016 I'm not interested in buying but I would love to see it. Next time you're taking a dump upload those pics to photobucket and post image links here.Haha, true! Quote
Derrickc14 Posted July 31, 2016 Author Report Posted July 31, 2016 (edited) Sorry guys if you want to pm me i will send you pics if you give me your cell number. I tried to do photo bucket but it just puts all my pics in. I dont know how to insert one photo at a time. Edited July 31, 2016 by Derrickc14 Quote
hercalmighty Posted August 1, 2016 Report Posted August 1, 2016 (edited) https://philadelphia.craigslist.org/snw/5698990530.html Is this your cl ad Sent from my VS990 using Tapatalk Edited August 1, 2016 by hercalmighty Quote
rjdgriff Posted August 1, 2016 Report Posted August 1, 2016 Good luck with sell. I just sold my 10mil serval for 6k. Green and white 4 servo, 10 servo, 10 cub, 10 dm, gigidy Quote
guns4children Posted August 3, 2016 Report Posted August 3, 2016 Good luck with sell. I just sold my 10mil serval for 6k. Green and white 4 servo, 10 servo, 10 cub, 10 dm, gigidy Time to take it out of your signature. 1 Quote
rjdgriff Posted August 3, 2016 Report Posted August 3, 2016 It will be on Friday when dicksmack comes and picks it up lol 4 servo, 10 servo, 10 cub, 10 dm, gigidy Quote
