Not throttle response
Hi guys
Sometimes after warmmed up when i apply a WOT. Not response correctly. It give a kind of jostle (or sound choky) and after I keep WOT a few seconds starts to respose slowly and i can run full throttle.
What the problem?
Stock carbs with 300 mains 27.5 pilots (tors on it but disconnected)
V force 4
Shaved head
Stock cdi coil and stator
Plugs looks brown color, not rich, not lean
No hard start
Before put the v force and shave the head also made all that
Sent from my SM-A500Y using Tapatalk
Okay. First thing to do is make sure the slides are in the correct carbs.
Is it good gas?
Clean correct plugs?
Ratio correct?
Have you done anything to see if you can fix it
Yes the slides are in correct position, half moon in the airbox direction
Yes is a good gas because other buddies don't have trouble with the same gas
I have not cleane the plugs, ¿how to do? And what plugs? Spark plugs? Harness plugs?
Mix ratio? I use 32:1 ratio
Is it good gas?
Ratio correct?
My banshee do similar like this but in high revs and the tors and parking brake and is disconnected
https://youtu.be/INQF4uY-Q2w
Did you ohm the coil?
Pick up gap okay?
300 and 4th notch is fairly rich for you too
Sent from my SAMSUNG-SM-G890A using Tapatalk
Not. but i'll do
Yes pick up gap is okay
What jetting and notch do you recommend?
