Sandman77 Posted July 12, 2016 Report Share Posted July 12, 2016 So I am new to the Banshee and come from 4 strokes so please forgive my ignorance I am trying to learn. I recently purchased a barn find 2003 Banshee that the motor was seized. I tore it apart last night to find it has a 4mm HotRods stroker crank and Wampus Cylinders. The Cylinders need to be re plated and new pistons (obviously). So my question is before I send cylinder(s) to Mellinium I am going to buy pistons for it, Can I bore it to 72mm safely or would I be better off just staying at 68mm bore. Thank you... Quote Link to comment Share on other sites More sharing options...
JTmachining Posted July 12, 2016 Report Share Posted July 12, 2016 So I am new to the Banshee and come from 4 strokes so please forgive my ignorance I am trying to learn. I recently purchased a barn find 2003 Banshee that the motor was seized. I tore it apart last night to find it has a 4mm HotRods stroker crank and Wampus Cylinders. The Cylinders need to be re plated and new pistons (obviously). So my question is before I send cylinder(s) to Mellinium I am going to buy pistons for it, Can I bore it to 72mm safely or would I be better off just staying at 68mm bore. Thank you... If it's a small bore cyl then u can't make it a big bore cyl. Two diff cyls. Welcome to BHQ Quote Link to comment Share on other sites More sharing options...
Sandman77 Posted July 12, 2016 Author Report Share Posted July 12, 2016 If it's a small bore cyl then u can't make it a big bore cyl. Two diff cyls. Welcome to BHQ Thank you. So its my understanding that stock is 64mm The Wampus is a 68mm cub designed to look stock. Basically What is the max a Cub can be bored to then? Quote Link to comment Share on other sites More sharing options...
JTmachining Posted July 12, 2016 Report Share Posted July 12, 2016 Thank you. So its my understanding that stock is 64mm The Wampus is a 68mm cub designed to look stock. Basically What is the max a Cub can be bored to then? Not much more than 68mm Quote Link to comment Share on other sites More sharing options...
Sandman77 Posted July 12, 2016 Author Report Share Posted July 12, 2016 That answers my question. Thank you! I'll order 68mm pistons thank you for the quick response guys Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted July 12, 2016 Report Share Posted July 12, 2016 That answers my question. Thank you! I'll order 68mm pistons thank you for the quick response guysI believe millennium has pistons on hand. They will measure the pistons and match them to the cylinder Also if the motor seized I'd be pulling the crank out and inspecting that. A hot crank is never a good thing. 1 Quote Link to comment Share on other sites More sharing options...
