First plug shop on the DL/Sniper/35mm combo
I think i got a leak.... It passed the leak test (from 6 to 5.5lbs in 20min.) 2 month ago, but i just saw a little bit of oil by the crank seal...
Will redo a leak test later tonight..
What do you mean oil by the crank seal? where will you see that at on the case? the right side by the water pump?
Nope, i removed the flywheel cover and i saw a little bit of oil behind the timing plate... Not sure if it's old oil from when i did the assembly or new one...
How do you like the driveline cylinders? Im from Michigan and they just did a great job dyno'ing my bike for me. Im highly considering doing their 421 after summer.  Did you have additional porting done to yours?
Bill (bansheehp) did my porting on my LP cylinders amd Lane is a good guy to deal with too.
The engine is not fully tuned yet, but i have way moe power than my previous setup (ported stock cyl).
Great price, Great guys, lots of power, what else can you ask?
Indeed, I had a good experience with them.  I only live 20 mins away from them too :) Good stuff man, Ill be following this thread to see how it turns out
Got carbs and filters on it yet?
Yes, I'm tuning it, I removed the tank to do a compression test, without bending the hose.
I'll take a pic from top with pods on.
I like the way the silencer are connected to the stingner with orings, it give you about 2 inchs of 'travel'
Envoyé de mon GT-P5113 en utilisant Tapatalk
