RedBanshee99 Posted June 29, 2016 Report Share Posted June 29, 2016 I am wanting to do a trail/dune build and I was thinking of doing a serval 421 4mil, advanced timing, toomey t6's, vforce4, and a 2-1 with a 38mm pwk. Thoughts? Quote Link to comment Share on other sites More sharing options...
JTmachining Posted June 29, 2016 Report Share Posted June 29, 2016 All sounds good but the pipes/2-1 Quote Link to comment Share on other sites More sharing options...
RedBanshee99 Posted June 29, 2016 Author Report Share Posted June 29, 2016 What pipes should I go with? And I have been told that with a 2-1 I can get more low end, plus I usually go on long rides and hate the thumb fatigue but I dont like twist throttles. Any suggestions? Quote Link to comment Share on other sites More sharing options...
Sandking Posted June 29, 2016 Report Share Posted June 29, 2016 The serval drinks a lot of gas, if you go on long rides stick with the stock cylinders maybe ported. Quote Link to comment Share on other sites More sharing options...
bluebanshee98 Posted June 29, 2016 Report Share Posted June 29, 2016 The motor is a good choice. The carbs 2- 35 pwks would be good. Pipes will depend on what you want the motor to do but sniper, cpi or shearer pipes will let the motor breath and make more power. For thumb fatigue using a Honda throttle and or cut springs from FAST will help. There is also other throttles available to use. A good new lubed up cable helps as well. Quote Link to comment Share on other sites More sharing options...
RedBanshee99 Posted June 29, 2016 Author Report Share Posted June 29, 2016 I figured a serval would be a gas hog so I'm also going to be putting a 5.5 gal fuel tank on it. But just or of curiosity long can you ride not wide open most of the time on a stock tank with a serval? And ok I'll look into the Honda throttles and cut springs. And which exhaust performs better for low to mid power? I'm not real concerned about top end because a banshee has the of top end anyway. Quote Link to comment Share on other sites More sharing options...
RedBanshee99 Posted June 29, 2016 Author Report Share Posted June 29, 2016 And would a redline 4mil stock cyl put out roughly the same torque as a fast 421 4mil serval? I've heard they're very comparable. Quote Link to comment Share on other sites More sharing options...
RedBanshee99 Posted June 29, 2016 Author Report Share Posted June 29, 2016 And is the power as user friendly and smooth on the redline? Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted June 29, 2016 Report Share Posted June 29, 2016 Look in the Dyno section, lots of setups. Also search SLP pipes. Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted June 29, 2016 Report Share Posted June 29, 2016 Start calling builders and discuss it with them. With their porting and knowledge, Youll be better off. It may not be cheap but it will be done right the first time with their guidance. 1 Quote Link to comment Share on other sites More sharing options...
Surfrjag Posted June 29, 2016 Report Share Posted June 29, 2016 I would run 28pwk and pro circuits Run race gas with timing and compression. Guess i need to do it any dyno it to see but i thinknit would be a good combo Quote Link to comment Share on other sites More sharing options...
newwarrior333 Posted June 29, 2016 Report Share Posted June 29, 2016 Just wondering if anyone has built a super cub 472? If so can I use stock transmission? Gears? Sent from my SM-G900W8 using Tapatalk Quote Link to comment Share on other sites More sharing options...
hp2000 Posted June 29, 2016 Report Share Posted June 29, 2016 I am wanting to do a trail/dune build and I was thinking of doing a serval 421 4mil, advanced timing, toomey t6's, vforce4, and a 2-1 with a 38mm pwk. Thoughts?My vote goes for Trinity pipes and a 2-1 well tuned is a great trail set up and not a slouch as many say it is on the top end. Here's my set up: Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
lastnline75 Posted June 30, 2016 Report Share Posted June 30, 2016 My vote goes for Trinity pipes and a 2-1 well tuned is a great trail set up and not a slouch as many say it is on the top end. Here's my set up: Sent from my iPhone using Tapatalk Is that a serval? FKN JUNK Quote Link to comment Share on other sites More sharing options...
bluebanshee98 Posted June 30, 2016 Report Share Posted June 30, 2016 Is that a serval? FKN JUNK I think it a stock cylinder if my eyes don't deceive me Quote Link to comment Share on other sites More sharing options...
