87sheerips Posted June 28, 2016 Author Report Posted June 28, 2016 Agreed. The rear should sit higher than the front normally and it should level out with a trailer. A bit of a rake is good - yes I just think the rammer is a bit extreme and I will never fall anything that heavy to make your SAG. At the end of the day I'll probably leave it the hell alone - or maybe flip that rear spacer block and get an inch lower. Thank you all for your kind and Thoughtfull remarks Quote
rubberneck Posted June 29, 2016 Report Posted June 29, 2016 The rams have too much rake and look gay as fuck stock. Not to mention with time its the the front end that sags on these trucks. The opposite may be true on a gasser but not when you have about 1200 pounds of motor sitting on those front springs for years at a time. Tyler you should be ashamed, they are going to repossess your white oakleys if you leave the back of the truck higher than the front. Quote
