Want a level stance but sometimes I have to park in garages... And I'm already cutting it close....
Thinking of lowering rear a couple inches instead of lifting front.
Let us discuss.
I'd go to those garages and take good measurements. A 3" lift over the front axle will not yield a 3" height increase at the tallest point of the cab.
Sent from my SAMSUNG-SM-G891A using Tapatalk
  • Like 1
Chicago I was what looked to be about an inch of clearance - local hospital
Is also sketchy.... 7' clearance is typical.
Just kicking around ideas - looks like people remove the spacer block
Under the leaf springs to drop the ass an inch or so - but I really don't want to jerry rig my expensive ass truck.
Looking for ideas. Id rather lift a bit but
I don't want to hinder where I can or cannot park...
This. Also bigger tires will lift anything vert more than a lift will
Wants level...
Doesn't want leveling to lift front and make to tall to fit...
Wants to know how to lower rear without hack job....
Call deaver, change your leafs...
Edited by kawa110
  • Like 1
If u copy the block angle and design (if it has a hole or locator etc) u can make one. Jus make sure pinion angle is good and u get new u bolts/nuts
JD i havent fucked with your year truck but on my dads 06 dually it had a spacer block on top of the axle perch. It was about 1.5 " thick if i remember.  All we did was remove the block and place it on top of the spring.  You could remove it entirely but would need new U bolts.  It works flawlessly and unless you know what you are looking at you would have no clue it was even done besides the truck sitting more level.  He did it to try and get his 5th wheel closer to level as the trailer already had the axles flipped but was still too low.
