Whitbread Posted July 1, 2016 Report Share Posted July 1, 2016 40:1 of klotz super techniplate for at least 12 years now. Never had a lube failure even when spiked lean. Piston top melted before the bore scuffed. Quote Link to comment Share on other sites More sharing options...
kenny_r Posted July 1, 2016 Report Share Posted July 1, 2016 I run 927 at 40:1, never had any issues. Quote Link to comment Share on other sites More sharing options...
kawa110 Posted July 1, 2016 Report Share Posted July 1, 2016 (edited) Klotz for drive gears all bikes. Klotz for motor oil in kawa 110 Yamalube in the shee's Golden specrto in 2003 cr250 Castor 927 in 1978 yz 250 32:1---I'll ride like a fool Over-revving and it stupid hot weather. ^^^comes down to personal preference. Sent from my iPhone using Tapatalk Edited July 1, 2016 by kawa110 Quote Link to comment Share on other sites More sharing options...
kawa110 Posted July 1, 2016 Report Share Posted July 1, 2016 I know I'm dumb.... Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted July 1, 2016 Report Share Posted July 1, 2016 Why do you run different oil in each machine, wouldn't it be easier and simpler to run the same premix in every machine and run the same ratio? that way you don't need to have many gas cans, one for each machine. Yup, i run everything with the same oil (synt 2 strokes) and the same ratio (50:1). Way more convenient!! Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted July 1, 2016 Report Share Posted July 1, 2016 Klotz 40:1-32:1 in everything from banshee to xr80 hell, even had some in the 450r. Lawnmower weed whacker pressure washer. Just easier that way 1 Quote Link to comment Share on other sites More sharing options...
thomas h. Posted July 1, 2016 Report Share Posted July 1, 2016 36:1 Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted July 1, 2016 Report Share Posted July 1, 2016 32:1 dominator and that is the only way to go. You get negligible wear. main thing is; your machine shop/engine builder gets you a round-perpendicular bore and you break in the engine correct. suffice it to say, but have your jetting favoring the richdoesn't dominator call for 50:1 right on the bottle Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted July 1, 2016 Report Share Posted July 1, 2016 Idea... Read the manufacturers reccomendation as they have probably tested and melted several motors to verify what is needed with their product. Obviously some are better then others. I got on the synthetic train for a while and did every ratio from 32:1 all the way up to 50:1. Synthetics in my experience do not protect as well at 50:1, but leave more deposits when mixed at 32:1. After really looking at my motor parts I went back to Blendzall and Castor 927. Flawless. 1 Quote Link to comment Share on other sites More sharing options...
sangheraent Posted July 4, 2016 Report Share Posted July 4, 2016 canadian tire oil 80:1. been running it for years its like $3 a quart. gets the job done. sometimes I run snowmobile injector oil if i have it left over from the season. Quote Link to comment Share on other sites More sharing options...
Craig B Posted July 4, 2016 Report Share Posted July 4, 2016 I was running 927 or Klotz benol @ 32.1 with 110. If the quad sat for a week or so and I went to start it the pilot jets would be clogged. Not sure if it was just the cold weather or the castor oil. I switched to Amsoil Dominator and have no starting/ idle issues. Quote Link to comment Share on other sites More sharing options...
Scrubby Posted July 4, 2016 Report Share Posted July 4, 2016 I know castors aren't cold friendly. Quote Link to comment Share on other sites More sharing options...
jwhitt Posted July 12, 2016 Report Share Posted July 12, 2016 Redline synthetic, 1 bottle per 5 gallons. Only issues I have had is that not all shops carry it so I have had to run around town a bit on some trips to find it and it costs around $11 a bottle. Quote Link to comment Share on other sites More sharing options...
