RedBanshee99 Posted June 27, 2016 Report Share Posted June 27, 2016 So here's the deal guys, I live in Wyoming in the mountains with some really good trails sound here but I also live close to sand dunes. I'm wanting to build a banshee that I can take up and trail ride in the mountains but also take to the dunes and rip, what would I have to do to one to make a great all around quad. I know there's quads out there more suited for stuff like that but a banshee is my favorite so any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
bigweav81 Posted June 27, 2016 Report Share Posted June 27, 2016 Look into a serval set up. Also driveline cylinders come with a similar port timing. You can have your stock cylinders ported as well. Search, and read. Sent from my SM-S820L using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
JTmachining Posted June 27, 2016 Report Share Posted June 27, 2016 A dirt and dune set up can be very similar. Anything set up for dirt can be used in the dunes. How is the bike set up now? Post pics and info and we can help u Quote Link to comment Share on other sites More sharing options...
RedBanshee99 Posted June 27, 2016 Author Report Share Posted June 27, 2016 Completely stock, I just picked it up. It's in shambles right now I'm trying to get it back together and running right but I want do the necessary work to make it a good quad for everything. The tails I are very tight and technical with allot of steep hills in trying to figure out motor setup and best suspension setup. I'm also thinking about going to a single larger carb. What do y'all think? Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted June 27, 2016 Report Share Posted June 27, 2016 Ok then, lets talk about $$$, what's your budget? Quote Link to comment Share on other sites More sharing options...
bigweav81 Posted June 27, 2016 Report Share Posted June 27, 2016 (edited) Buy a clymers manual. You will be leaps ahead upon re assembly........search any topic you find yourself pondering. Literally Google your questions, and end it with banshee. I've hung around since 2013, and can only think of 2 times I had a question I couldn't answer by searching. Start thinking of a budget, and go from there. Good luck, and welcome to BHQ. We offer advice on many subjects, banshee, financial, marital, divorce, etc. I encourage you to start off on the right foot, and post some pics of your wife, gfs, sisters.....you get the point. Sent from my SM-S820L using Tapatalk Edited June 27, 2016 by bigweav81 3 Quote Link to comment Share on other sites More sharing options...
JTmachining Posted June 27, 2016 Report Share Posted June 27, 2016 Completely stock, I just picked it up. It's in shambles right now I'm trying to get it back together and running right but I want do the necessary work to make it a good quad for everything. The tails I are very tight and technical with allot of steep hills in trying to figure out motor setup and best suspension setup. I'm also thinking about going to a single larger carb. What do y'all think?Tight trails= Get aftermarket stock width or plus one width a arms and wheels with the offset to keep track width narrow. Fireball Racing make awesome a arms and swingarms etc. Fox or Elka shocks make a big diff in dirt/dunes. I use all DWT wheels. Peeps are going to lol but one of my fav pipes are FMF fattys. Carb set up is up to u but that's a factor depending on mtr mods 1 Quote Link to comment Share on other sites More sharing options...
Dunatic619 Posted June 27, 2016 Report Share Posted June 27, 2016 do suspension first, then do motor. Power is useless unless you can get it to the ground. Banshee suspension sucks a bag of dicks. You'll want to get the best you can afford. Comb the for sale forums. Lots of stuff can be had cheap. May not be pretty, by it'll work. 1 Quote Link to comment Share on other sites More sharing options...
Surfrjag Posted June 27, 2016 Report Share Posted June 27, 2016 Mine in my sig is built for both. Stock cyl 4mil . +2 a arms and axle with works shocks. +1 swingarm Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted June 27, 2016 Report Share Posted June 27, 2016 How wide are the trails in your riding areas? Quote Link to comment Share on other sites More sharing options...
RedBanshee99 Posted June 27, 2016 Author Report Share Posted June 27, 2016 Some trails are narrow but for the most part they'll be decently wide. Is there any benefit to running a single carb? If how big should I go? I was thinking a 38mm Quote Link to comment Share on other sites More sharing options...
JTmachining Posted June 27, 2016 Report Share Posted June 27, 2016 Some trails are narrow but for the most part they'll be decently wide. Is there any benefit to running a single carb? If how big should I go? I was thinking a 38mm2>1 1 Quote Link to comment Share on other sites More sharing options...
rjdgriff Posted June 28, 2016 Report Share Posted June 28, 2016 Run twin carbs for sure Trail Bikes, FTW Quote Link to comment Share on other sites More sharing options...
