Jetting for serval vs cub
They should be nearly identical.
Are those both regular PWK or is one set Airstrikers?
The Serval is spot on or maybe a little bit rich.
That Cub jetting is fucky.
How do I tell the difference between air strikers and regular?
They look identical to the serval PWK's.
Watch with those hose clamps on the intake I've see them wear boots, most intakes spec the thinner style
they did come with smaller clamps, but i found them cutting up the intake. maybe i tighten too much?
I think something is going on with the bike with 180s.
In 13+ years of running PWK I've never had 180s in anything.
Any ideas sir?
i think ill do a leak down on it again to double check no leaks. but if it has no leaks?
