01_BlackBitch Posted June 22, 2016 Report Posted June 22, 2016 (edited) I just had purchased a banshee recently. The right side pipe smokes a BIT more than the left (yes it is a noticeable amount, no its nothing crazy. it also has no smell). It leaves the right silencer wet and it also spits oil were the expansion chamber and silencer pipe meet. It smokes more at idle when cold but not so much when it warms up...It spits oil regardless of temp. The right side pipe does not warm up near as fast as the left.The left side seems to "ping" alot harder than the right as well.Right side plug was wet/black when checked. I know no one here can tell me just based off this what is going on.... but im looking for educated guesses and points in the right direction....Just praying its not a crank seal on the right side...... Edited June 22, 2016 by 01_BlackBitch Quote
Yamahafan#1 Posted June 22, 2016 Report Posted June 22, 2016 (edited) Sound like that sides running to rich, wat dose your other plig look like? Make sure ur air screws are ajust right to, Check pick up gap on stator, Should .018 to .020 And check ur spark plug gap should be between .028 and .032. nd sync carb slides. I just had this problem on mine luteraly fixed it last night by doin all this. It was same cylinder as u and everything Edited June 22, 2016 by Yamahafan#1 1 Quote
Yamahafan#1 Posted June 22, 2016 Report Posted June 22, 2016 (edited) So for the slopy typing was busy wile i was type befor. Also have u done a compresdion test recently ? But hate to say it the more i read ur post it sound like crank seal, hope not though good luck Edited June 22, 2016 by Yamahafan#1 Quote
sleeper06 Posted June 22, 2016 Report Posted June 22, 2016 I would ohm out plug caps, and check electrical . You might have a lazy reed on that side. Could be a bad plug Quote
01_BlackBitch Posted June 28, 2016 Author Report Posted June 28, 2016 The right size carb had a 58 pilot in it... Left side has 55 Waiting for another 55 To come in the mail. Hope thIs is it Quote
