Hello , I will me soon build a 421cc engine.
my setup :
-68mm Kit Driveline Assassin's HP
-Dome 21cc
-Keihin 38mm pwk
-Shearer out of frame with silencer
-crank +4mm
-Tassinari V-Force 4
Would you have any idea of mainjet ,that i must take ?
I see a lot of setup 421cc with 35mm carbs and mainjet about 140~170. but with 38mm carbs ? i did not find.
last question : i have a timing plate (at the moment +4° @stock cylinder). But with this setup ,How many can I put ? my use is only onroad.
Thank you for your help :)
Edited by NitroObsidian
What kind of road , like daily driving or drag racing on asphault,. 21cc domes are gonna leave u needing over 100 octane fuel timings depends on intended use jetting will vary with compression/timing/fuel so know what you want to run..what pipes do you have?
