I'm 1000 ft above sea level, bored .050 over pro x piston, toomey t5s, vf3, cool head with 21 cc domes, chariot cross over intake, +4 timing no air box lid. what I have now is a 25 pilot and the main is 340 that seems huge just looking for some input thanks
Sent from my SM-G920V using Tapatalk
27.5 pilot
Middle clip on needle (fine tune after)
280-290 main
  • Like 1
27.5 pilot
280-290 main
If the OP's motor is air tight, the above jetting will be very, very close.
OP, inspect the intake boots for cracks.
Re-torque all reed cage and intake screws.
250in•lbs or 20ft•lbs
Seat both airscrews gently and turn them out 1/2 a turn at time until they're 1-1/2 turns out.
But all of the above needs to happen first, then the following needs to happen.
Is TORS eliminated?
Is your idle set to ~1,500 rpms?
Are your carbs sync'd at idle with a FAST Sync tool?
Are your carbs sync'd at part throttle?
