Bunch of Parts For Sale
All prices are for parts only. Shipping will be added. We all know what flat rate usps boxes cost. Will do package deals.will sell whole lot .
yfz450 spindles hubs rotors 40
  one hub is missing spacer in between bearings
banshee hub w/rotor    15
clutch fibers and steels two full sets one stock the other ?  10
head   10
kicker gear  15
idler gear  10
crank gear 10
clutch nut washer and bearing 20
sprocket nut and sleeve  10
crank nuts both sides and keys  20
trans clips 5
presure plates 15
clutch hub 15
dual stage reeds  30
clutch arm  10
sprocket and hub  15
brake hub  15
cylinders  65.00 need a bore  80
shifer  10
light and run switch  20
nuetral sw cover  5
shift shaft  10
shock good  50
water pump cover 5
lights for parts 10
k and n filters for stock or 28 mm carbs 15
upper left a arm  15
rad cover w panty dropper 20
front brake master cylinder 10
rad hoses all for 10
rear linkage  40
steering stem mounting blocks  15
tail light 10
rear brake lt switch 10
clutch cover 20
flywheel cove 10
tie rods stock 10
foot pegs w bolts 25
throttle   25
front brake line lower one  5
two stock frames  100 each
carbs stock 50 for all
clutch springs heavy  normal and stock 15 for whole box
front fender supports 20
timing plate 5
coil missing one cap 10
rear chain guide 10
443 617 3865 text w any questions rob
paypal is
robertlovett@live.com
leave a note saying what its for
  • Like 2
