ILbansheeMike Posted June 14, 2016 Report Share Posted June 14, 2016 Hey everybody this is my first post on here! I just recently picked up a 1987 Banshee it was running when I got it but very low compression so I decided to start tearing it down. The pistons that were in it are 66.25 mm and the cylinders look like they could use a bore so my question is should I get the cylinder bored out for a 66.5mm piston or would that be pushing the stock Jug? I called the local Yamaha dealer they said they wanted $125 per cylinder to bore them which seemed pretty expensive? I was looking at some big bore rebuild kits but I don't know much about whats out there, If anybody could give me any suggestions on what I should do i would really appreciate it! Thanks, Mike. Quote Link to comment Share on other sites More sharing options...
tfaith08 Posted June 14, 2016 Report Share Posted June 14, 2016 I'd let the pros decide whether the cylinders only need to go to 66.5. If it was me, I'd invest in something new.You can find some used stock jugs on a smaller bore and have them ported or go with Driveline or some CP cylinders. Quote Link to comment Share on other sites More sharing options...
guns4children Posted June 15, 2016 Report Share Posted June 15, 2016 For what they want to bore the. You could buy new ones. 2 Quote Link to comment Share on other sites More sharing options...
ILbansheeMike Posted June 17, 2016 Author Report Share Posted June 17, 2016 Thank you for the advice I appreciate it, I ended up calling around and found a shop that said they would do it for 60 a cylinder. I dropped it off a few days ago waiting to here back if it will need a bore or hone. Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted June 17, 2016 Report Share Posted June 17, 2016 Going that big you need to make sure dome/head is clearanced properly otherwise your squish band will not be kosher Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted June 17, 2016 Report Share Posted June 17, 2016 Are they boring without the pistons on hand? Quote Link to comment Share on other sites More sharing options...
Yamahafan#1 Posted June 17, 2016 Report Share Posted June 17, 2016 (edited) Are they boring without the pistons on hand? Exactly what i was gonna ask lol Edited June 17, 2016 by Yamahafan#1 Quote Link to comment Share on other sites More sharing options...
ILbansheeMike Posted June 17, 2016 Author Report Share Posted June 17, 2016 I'm not sure if there boring them on hand, I dropped them off three days ago he said he would call me and let me know what needed to be done, still haven't heard from him and I tried calling no answer hoping to here back soon so I can figure out what piston size to order.I was looking into the 392 assassin big bore kit also has anybody had experience with this kit or heard anything good or bad about it? Quote Link to comment Share on other sites More sharing options...
ILbansheeMike Posted June 17, 2016 Author Report Share Posted June 17, 2016 Sorry I miss read you're comment, I'm not sure if they have the pistons on hand at the shop or not Quote Link to comment Share on other sites More sharing options...
Yamahafan#1 Posted July 11, 2016 Report Share Posted July 11, 2016 (edited) Sorry I miss read you're comment, I'm not sure if they have the pistons on hand at the shop or not you want them to get the pistons pre boreing the cylinders becuz, piston arent perfect size there allways a little bit off, and the shop ur geting work done from should do it this way if they do it right everything needs to be in spec to run optimum and run a lomg life. They usally set the ring gap to but u should allways double check em when there in ur hands Good luck with ur build. Edited July 11, 2016 by Yamahafan#1 Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted July 11, 2016 Report Share Posted July 11, 2016 I'm not sure if there boring them on hand, I dropped them off three days ago he said he would call me and let me know what needed to be done, still haven't heard from him and I tried calling no answer hoping to here back soon so I can figure out what piston size to order.I was looking into the 392 assassin big bore kit also has anybody had experience with this kit or heard anything good or bad about it? Been lots of positive feedback on them. Look in the Sponsor Spotlight topics Quote Link to comment Share on other sites More sharing options...
