nastyracing Posted July 7, 2016 Author Report Posted July 7, 2016 I still have the set of 64.5mm cylinders with the Vito's superstock pistons I can do 285$ shipped on them . They do not have head studs any more and one of the holes will need to be time serted or re heli coiled . Otherwise a mint top end came apart 160 psi in each hole Quote
bluebanshee98 Posted July 12, 2016 Report Posted July 12, 2016 Do you have a good working oem stator? Works with the lights on as well? Quote
elconor Posted August 8, 2016 Report Posted August 8, 2016 Got a good shape clutch basket? (Tried to pm, wont go through) Quote
nastyracing Posted August 8, 2016 Author Report Posted August 8, 2016 My inbox is full I will clear it out now . No clutch baskets right now tho sorry Quote
Atlbanshee Posted August 15, 2016 Report Posted August 15, 2016 I want those carbs Sent from my SM-G930T using Tapatalk Quote
1000rrstunna Posted August 24, 2016 Report Posted August 24, 2016 Will the +2 swing arm take stock style skid plates for trail riding ? Gonna build a 4mil this winter should help keep the wheels down lol. Lmk I tried a pm but I can't Quote
nastyracing Posted August 24, 2016 Author Report Posted August 24, 2016 There is no swing arm mount tabs on the swing arm , but yes the plus 2 swing arm will defiently help keep front end down on launches with bigger motor , also at +2 still not to long to get the big to turn tight corners and track ride . Jds does make some nice rotor and sprocket guards if skid plates or protecting the rear is a must to you Quote
