Caster adjustment?
Craig B
I used ^^^ same exact write up.
I made a tool from 1" sq steel bar as long as the opposing faces of the knuckle are from one another.
Drilled a hole on one end of the bar centered and about the same size as the hole in the knuckle where the ball joint seats.
Then on the opposite side I drilled the same hole centered.
I then fixtured the part held by the holes and faced all four sides parallel to the axis of the holes.
With my Fireball LT a-arms mounted to the frame I inserted both ball joints into the holes and held them tight with a soft jawed clamp.
Then I used a $30 digital angle finder from Harbor Freight to set caster.
I set my caster at 6*.
Be prepared to need a steering stabilizer if you go with 6* or less.
