Presidentlincoln Posted June 11, 2016 Report Share Posted June 11, 2016 Doing a motor rebuild/case swap and noticed something different with the two cases there is two blots tapped out on my new cases that were not on my old cases and I was just wondering if anybody might have an idea why. There located behind the idler gear and above the kickstart start Sent from my SM-G920V using Tapatalk Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted June 11, 2016 Report Share Posted June 11, 2016 Probably something for the rz. I bet the speedometer, I've seen old cases with a rubber plug in top Quote Link to comment Share on other sites More sharing options...
Presidentlincoln Posted June 11, 2016 Author Report Share Posted June 11, 2016 Probably something for the rz. I bet the speedometer, I've seen old cases with a rubber plug in top What's the rz? Sent from my SM-G920V using Tapatalk Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted June 11, 2016 Report Share Posted June 11, 2016 What's the rz? Sent from my SM-G920V using Tapatalk Street bike with a banshee motor. Pre banshee Sent from my SAMSUNG-SM-G890A using Tapatalk Quote Link to comment Share on other sites More sharing options...
Presidentlincoln Posted June 11, 2016 Author Report Share Posted June 11, 2016 Street bike with a banshee motor. Pre banshee Sent from my SAMSUNG-SM-G890A using Tapatalk Now I want one Sent from my SM-G920V using Tapatalk Quote Link to comment Share on other sites More sharing options...
kawa110 Posted June 11, 2016 Report Share Posted June 11, 2016 ^^^^^^^ that is ( . ) ( . ) I want one and the prices are only going up....just like banshees everybody wants a fortune for there junk!!!!!! Quote Link to comment Share on other sites More sharing options...
bhatch21 Posted June 14, 2016 Report Share Posted June 14, 2016 (edited) Don't settle for an rz350 when you can have it's big brother, an rz500. 4 cylinders are better than 2. I've seen some of those priced for 15k or more. Edited June 14, 2016 by bhatch21 2 Quote Link to comment Share on other sites More sharing options...
Yamahafan#1 Posted June 19, 2016 Report Share Posted June 19, 2016 I had a 87 banshee with rz 350 motor. Gear ration was way to long for the street. But it was fast in the long run. Quote Link to comment Share on other sites More sharing options...
Surfrjag Posted June 19, 2016 Report Share Posted June 19, 2016 Speedo on the rz goes right in the top. Banshee has it but its blocked off. Right behind the clutch cable hold down. Not sure what those are tapped for though. Btw that idler gear bushing is toast! Quote Link to comment Share on other sites More sharing options...
Surfrjag Posted June 19, 2016 Report Share Posted June 19, 2016 Actually its rpm.. goes in where i described and spins off a shaft held in with those holes. Shown here. https://cloud.tapatalk.com/s/57669754970c3/0_0.png Sent from my SM-G930V using Tapatalk Quote Link to comment Share on other sites More sharing options...
Surfrjag Posted June 19, 2016 Report Share Posted June 19, 2016 http://www.cheapcycleparts.com/oemparts/a/yam/50042665f8700209bc788594/tachometer-gear Sent from my SM-G930V using Tapatalk Quote Link to comment Share on other sites More sharing options...
