Piston weight question
OK so I was about to order some pistons for my bike and was going to go with the prox pistons like I always do and have been for years never had a problem.
But I had a set of wiecos on my bench and I compared the weight I don't have a scale but I used the feeling method it felt like 1 prox piston is almost as heavy as 2 wiescos.
How much would this affect power? I'm no motor expert but something tells me heavier piston means more power required to turn it. I doubt it will be a big difference but possible 1-2 hp.
Any thoughts?
Sent from my STV100-3 using Tapatalk
Wouldn't something like that effect the balance of an engine? I always thought they made pistons to match the crankshaft weight( of the :"lobe")
You can have the pistons balanced to the rotating assembly but most people don't bother.
  • Like 1
