sander.reijenga. Posted June 7, 2016 Report Posted June 7, 2016 Hello I need a jetting start for the next setup. I switched from stock carbs to 28mm pwk keihin 65mm bore Fmf fatties V force 4 28mm pkw Timing at +4 Sealevel. Mix 32:1 Can somebody point out a safe starting setup for the keihins so i can start plug chop. In stock carbs i was jetted 320 main needle stock and middle 27,5 pilot and 1.5 turns on airscrew Thanks in advance Verstuurd vanaf mijn SM-G900F met Tapatalk Quote
Surfrjag Posted June 7, 2016 Report Posted June 7, 2016 48 pilot Jjh or n68a needle in the middle clip 155 mains Quote
sander.reijenga. Posted June 7, 2016 Author Report Posted June 7, 2016 Ok so my needle is the problem Verstuurd vanaf mijn SM-G900F met Tapatalk Quote
sander.reijenga. Posted June 8, 2016 Author Report Posted June 8, 2016 Jjk Verstuurd vanaf mijn SM-G900F met Tapatalk Quote
