Pilot is dialed in when you can increase the idle a tiny bit by leaning/turning out the airscrews.
But in order to see the tiny increase, (couple hundred rpm) you need a digital tach from eBay.
Maybe add some fuel by raising the needle and putting the clip 1 groove below middle or 4th position.
Then do a proper plug chop.
motor locked up, looks like air leak on the left side.
thats more than likely the overheating.
need to get the leak sorted before i go any further with the jetting.
