Won't start
96 banshee, Did rings, got back together, was breaking in and it died. Figured out I had a broken reed, replaced them and it started and ran idled great, would start first kick, went to take it for first ride and it abruptly died, pretty much same simptoms as when reed broke. Now won't start, has spark, fuel, compression. Almost sounds like it fires out of time but not sure why it would do that, timing plate tight, haven't messed with anything.
make sure your plugs are good and gapped properly and you have a good spark. bluish spark is a strong spark orange/yellow is a weak spark. could also be an air leak or pull the flywheel cover and make sure your stator is in good shape and is timed
Sent from my SM-G935T using Tapatalk
