EaCastillo00 Posted June 5, 2016 Report Share Posted June 5, 2016 (edited) My axle has a play it moves even when braked please help, i attached a video so you can see, i think it may be a bearing, in the video you can only see one side of the axle, both sides move equally and sincronized, but it seems like the brake disk rotor moves separetly Edited June 5, 2016 by EaCastillo00 Quote Link to comment Share on other sites More sharing options...
EaCastillo00 Posted June 5, 2016 Author Report Share Posted June 5, 2016 (edited) sorry guys the video is to big for upload... Edited June 5, 2016 by EaCastillo00 Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted June 6, 2016 Report Share Posted June 6, 2016 Well FFS, try describing it. Is axle hub nuts tight ?? Quote Link to comment Share on other sites More sharing options...
EaCastillo00 Posted June 11, 2016 Author Report Share Posted June 11, 2016 Well FFS, try describing it. Is axle hub nuts tight ?? solved it it was the axle bearings, needed to be replaced, al done thanks Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted June 12, 2016 Report Share Posted June 12, 2016 HaHa, I was gonna ask, was your chain loose then tight, loose then tight, etc.? Glad you got it figured out. Quote Link to comment Share on other sites More sharing options...
Yamahafan#1 Posted June 20, 2016 Report Share Posted June 20, 2016 I just bent the shit out of my axel carrier bolt,the one that gos thru the chain tensoners. Yea got in my sproket hub and riped the nut right off and bolt bent to fuck. Had to beat it out. Quote Link to comment Share on other sites More sharing options...
