QuickClutchOsh95 Posted June 5, 2016 Report Share Posted June 5, 2016 Was riding my shee when it cut out in 3rd gear. The quad didn't bog down it just cut out and my plugs are no longer getting a spark. Any suggestions would be great. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted June 5, 2016 Report Share Posted June 5, 2016 Break out the clymer and an ohm meter and start testing components. Quote Link to comment Share on other sites More sharing options...
QuickClutchOsh95 Posted June 5, 2016 Author Report Share Posted June 5, 2016 Will do, I'll post if I find the issue Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted June 6, 2016 Report Share Posted June 6, 2016 Make sure flywheel didn't come loose and take out pickup coil , common issues I see alot Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted June 6, 2016 Report Share Posted June 6, 2016 Look for burned wires. Disconnect kill switch, jumper key switch. Is TORS and parking brake limiter deleted? All wire connections clean and tight?? Quote Link to comment Share on other sites More sharing options...
QuickClutchOsh95 Posted June 24, 2016 Author Report Share Posted June 24, 2016 I went through the wiring and the stator is bad. What stator should I get because I see them going for anywhere from 30 on eBay to 300 from some websites. I don't need anything special to run LED lights I just need something that will keep the old shee running good Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted June 24, 2016 Report Share Posted June 24, 2016 Try n find an oem one used, . If you have the dough call fast n get brand new oem one Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted June 24, 2016 Report Share Posted June 24, 2016 Ricky stator are very hit n miss I've seen people go through 3-4 before getting one that works Quote Link to comment Share on other sites More sharing options...
