sevrin.murin Posted June 1, 2016 Report Share Posted June 1, 2016 So my banshee decided that it only wants to run on my right side. I was told it's got a welded crank, ported and polished, pipes, dual K&N filters. Lately it's been firing on the right side occasionally at an idle it'll pop and fire. If I get on it then both sides will go. I just did a compression test and they're both at 135 even. I've swapped coils, Cdi boxs, reeds with another bike and multiple new spark plugs because the left side keeps fouling with gas and oil but it never even looks like it's fired. Any help would be great..https://vimeo.com/169022844 Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
B22 Posted June 2, 2016 Report Share Posted June 2, 2016 Swap stators with someone maybe? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
B22 Posted June 2, 2016 Report Share Posted June 2, 2016 Swap stators with someone maybe? Sent from my iPhone using Tapatalk Also, swap your plug wires and see if the issue stays on the same side or changes. I'm not as good as most on diagnosing these issues but it's a quick test. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
JordyRoo Posted June 8, 2016 Report Share Posted June 8, 2016 Sounds like stator, mine would run great but blow a plug on the one side after 2 hours. Replace the plug & she would be fine again. Had the stator rewound & shes good as new. Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted June 8, 2016 Report Share Posted June 8, 2016 Other than Stator, check pickup coil gap and make sure both same .018 and no rust on nubs. Quote Link to comment Share on other sites More sharing options...
