steering issue
when i've ride on stock a arms everything was good, ball joint arms tight, tie ends tight, run low and high speeds not play not uncontrol
i put +2 +1 arms, not play on steering when i slow riding all is normal but when run on high speed the steering turn more sensitive, more high speed more more decontrol
has stock shocks, 19" tire on front 20" rear, is the same setup on tire before and after put the +2 +1 and never issue on high speeds on stock arms
whats the problem? bad adjust on a arm tie rods?
all are tight, the problem is when change the speed, i can't run on top speed
