fastbanshee8 Posted June 2, 2016 Report Share Posted June 2, 2016 That's what I'll have to do does anyone have a link to buy 30 piolots http://farmandsandtoys.com/ocart2/atv/yamaha/banshee/mikuni-banshee-pilot.html?filter=53 Quote Link to comment Share on other sites More sharing options...
Buster91dg Posted June 2, 2016 Author Report Share Posted June 2, 2016 Does any one have any other ideas what I can do it definitely got better. It's just still not 100% in my opinion Quote Link to comment Share on other sites More sharing options...
bigweav81 Posted June 2, 2016 Report Share Posted June 2, 2016 Maybe play with needle clip position some more. Sent from my SM-S820L using Tapatalk Quote Link to comment Share on other sites More sharing options...
Buster91dg Posted June 2, 2016 Author Report Share Posted June 2, 2016 So I'm going to try putting the clip one the first spot (near the point) it defiantly is 95% better I put hose clamps around the boost bottle and put the 300 mains back in now she wants come up like crazy idk if it's a mid throttle problem or a main jet should I go to 310 mains? Quote Link to comment Share on other sites More sharing options...
fastbanshee8 Posted June 3, 2016 Report Share Posted June 3, 2016 You won't get it running 100% right until you get the right pilots in it. When you go with a richer pilot, it will make a difference all the way through the RPM range. The pilots flow fuel from the second you start it, until you kill it. I would just wait until you get the right pilots, so you aren't jetting it several times. Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted June 3, 2016 Report Share Posted June 3, 2016 Get rid of the boost bottle !! It WILL crack the carb boots!!! And if they do show signs of cracking replace them. Sooner or later they will start to leak!! Then your pistons will melt!! Quote Link to comment Share on other sites More sharing options...
