Larry's Shee Posted May 27, 2016 Report Share Posted May 27, 2016 Alls I did was file the angle down flat like one of the guys in this forum recommended here's a pic I'd do at least an 1/8" more so you have more adjustment and room for lock nut. Had same issue first time I did them. Quote Link to comment Share on other sites More sharing options...
Buster91dg Posted May 27, 2016 Author Report Share Posted May 27, 2016 I'd do at least an 1/8" more so you have more adjustment and room for lock nut. Had same issue first time I did them. So you'd recommend filing more off to get a better idle? Quote Link to comment Share on other sites More sharing options...
Sandking Posted May 27, 2016 Report Share Posted May 27, 2016 Your filing more off so the screw enters the body of the carb more and can lift the slide more. Quote Link to comment Share on other sites More sharing options...
Buster91dg Posted May 28, 2016 Author Report Share Posted May 28, 2016 Ok and no would thinks it' could have an air leak? Quote Link to comment Share on other sites More sharing options...
Buster91dg Posted May 28, 2016 Author Report Share Posted May 28, 2016 I did have to jb weld a spot before in the case under the crank and a little oil was coming from a stud I took the nut off the stud and but Yamaha bond haven't seen anything now all dry been dry for few weeks now Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted May 28, 2016 Report Share Posted May 28, 2016 Leak down. Quote Link to comment Share on other sites More sharing options...
Buster91dg Posted May 28, 2016 Author Report Share Posted May 28, 2016 Ok Ik I saw something on here abt a leak down test can someone please post me the link on how to use it Quote Link to comment Share on other sites More sharing options...
Buster91dg Posted May 30, 2016 Author Report Share Posted May 30, 2016 Leak down. So I did the leak down test 6psi for 6 minutes. Had a leak around the boost bottle the metal clamp is stretched so I bent it to make it tighter. It passed the leak down figured it would be all good and nothing. Still has that bog when you lug it and it start to pull in its powerband its like a small hick up. I have 290 mains and stock pilots and the needle is on the second one up from bottom I had it in the middle but still the same any ideas? Btw idles great now that the carbs where synced. Thinking abt getting new clamps and just a cross over tube and then see what happens. Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted May 31, 2016 Report Share Posted May 31, 2016 Definitely get rid of the boost bottle !! Only thing they do is crack the intake boots. And I can say that from experience!! And they didn't start leaking until 3yrs later , after I got rid of it, when I did some jetting. Either crossover or some PVC caps that fit in boots. Occasionally you can get a flat spot that seems impossible to get rid of. Not saying to stop trying, just don't drive in those conditions. Double/tripple check that carbs are clean, float level is correct, bowls on correct carb, all the stupid shit that gets overlooked no matter how many times posted or you've done it. Hell, even start double checking electrical, won't hurt. Quote Link to comment Share on other sites More sharing options...
Buster91dg Posted May 31, 2016 Author Report Share Posted May 31, 2016 Yeah true somethings things get over looked and do you think it's bec I dropped the Main from 300-290 I probably noticed the problem a week later Quote Link to comment Share on other sites More sharing options...
Buster91dg Posted May 31, 2016 Author Report Share Posted May 31, 2016 I still feel like 290"s are big for my setup .25 over no lid w outerwear fmf pipes boyessen reeds Quote Link to comment Share on other sites More sharing options...
Buster91dg Posted May 31, 2016 Author Report Share Posted May 31, 2016 temps 70-90 abt sea level for elevation Quote Link to comment Share on other sites More sharing options...
bigweav81 Posted May 31, 2016 Report Share Posted May 31, 2016 Definitely get rid of the boost bottle !! Only thing they do is crack the intake boots. And I can say that from experience!! And they didn't start leaking until 3yrs later , after I got rid of it, when I did some jetting. Either crossover or some PVC caps that fit in boots. Occasionally you can get a flat spot that seems impossible to get rid of. Not saying to stop trying, just don't drive in those conditions. Double/tripple check that carbs are clean, float level is correct, bowls on correct carb, all the stupid shit that gets overlooked no matter how many times posted or you've done it. Hell, even start double checking electrical, won't hurt. Quote Link to comment Share on other sites More sharing options...
bigweav81 Posted May 31, 2016 Report Share Posted May 31, 2016 What should be used for sealant on the pvc caps? Quote Link to comment Share on other sites More sharing options...
Buster91dg Posted June 1, 2016 Author Report Share Posted June 1, 2016 Use the pvc sealer Quote Link to comment Share on other sites More sharing options...
