Oldskool83 Posted May 24, 2016 Report Share Posted May 24, 2016 2 new vitos Head gaskets 87-06 $5.00 2 new swingarm pivot bearings 87-06 $2.002 new reed gaskets 87-06 $2.00Items not shown but found last night that will go with:2 new oem carb to air box rubber boots $51 bag (set) of front a arm delrin bushing $5 1 new 95-96 to 97-06 conversion CDI wiring plug kompulsive concepts (lets you older guys runs newer stuff) $5Used Items:1 used set of front yamaha sport atv 1" thick wheel spacers (adds 2" over all) $40.001 barely used stator with pick up coil 95-06 $60.00 tested and works1 used CDI 97-06 $80 tested and works1 used voltage regulator 87-06 $1 tested and works1 used stock carb bowl 87-06 $21 used fuel line T 87-06 Free1 used fuel line 87-06 Free1 used stator plate with hardware 87-06 $1.001 used air filter cage with newish uni air filter. $2.001 used 13T sprocket that was run 30 mins before gearing was changed. $3.00 1 set of stock carb pilot jets 25 Free 1 set of stock carb main jets 320 FreeItems SOLDFly wheel Grab bar Throw me $100 take it all or I play the part out game. I will accept paypay. 717-675-4472 Text. Will ship or meet if semi local. All these items were bought new except CDI, VR,& carb bowl. Quote Link to comment Share on other sites More sharing options...
Loosescrewzz Posted June 3, 2016 Report Share Posted June 3, 2016 Is it oem stator? Quote Link to comment Share on other sites More sharing options...
guns4children Posted June 3, 2016 Report Share Posted June 3, 2016 I see a Harrisburg area code Quote Link to comment Share on other sites More sharing options...
Shee_fast Posted June 4, 2016 Report Share Posted June 4, 2016 I'll take stator if it's a square plug Sent from my SAMSUNG-SM-N920A using Tapatalk Quote Link to comment Share on other sites More sharing options...
patrickb2 Posted June 6, 2016 Report Share Posted June 6, 2016 2 new vitos Head gaskets 87-06 $5.00 2 new swingarm pivot bearings 87-06 $2.00 2 new reed gaskets 87-06 $2.00 Items not shown but found last night that will go with: 2 new oem carb to air box rubber boots $5 1 bag (set) of front a arm delrin bushing $5 1 new 95-96 to 97-06 conversion CDI wiring plug kompulsive concepts (lets you older guys runs newer stuff) $5 Used Items: 1 used set of front yamaha sport atv 1" thick wheel spacers (adds 2" over all) $40.00 1 barely used stator with pick up coil 95-06 $60.00 tested and works 1 used CDI 97-06 $80 tested and works 1 used voltage regulator 87-06 $1 tested and works 1 used stock carb bowl 87-06 $2 1 used fuel line T 87-06 Free 1 used fuel line 87-06 Free 1 used stator plate with hardware 87-06 $1.00 1 used air filter cage with newish uni air filter. $2.00 1 used 13T sprocket that was run 30 mins before gearing was changed. $3.00 1 set of stock carb pilot jets 25 Free 1 set of stock carb main jets 320 Free Items SOLD Fly wheel Grab bar Throw me $100 take it all or I play the part out game. I will accept paypay. 717-675-4472 Text. Will ship or meet if semi local. All these items were bought new except CDI, VR,& carb bowl. Do you still have main jets Sent from my SM-N900P using Tapatalk Quote Link to comment Share on other sites More sharing options...
Banshee SE Posted June 6, 2016 Report Share Posted June 6, 2016 Sent you a pm Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
Oldskool83 Posted June 7, 2016 Author Report Share Posted June 7, 2016 some items are sold some are still forsale. all electronics are still around. $80 take the pile of parts. I want it gone. Quote Link to comment Share on other sites More sharing options...
Oldskool83 Posted June 9, 2016 Author Report Share Posted June 9, 2016 (edited) Following is left: 2 new vitos head gaskets $5.00 2 new reed gaskets 2.00 2 new oem carb to air box rubber boots $5.00 1 used and tested working correctly ricks motorsport stator with plate and pick up coil 95-06 style $60.00 (ran properly on bike) 1 used and tested working correctly OEM CDI 97-06 style $80.00 (ran properly on bike) 1 used and tested working correctly voltage regulator $1.00 1 used stock carb bowl $2.00 1 used fuel line T Free 1 used unit air filter and cage. Filter had maybe 2 rides on it. $2.00 1 used 13T front sprocket with 1 ride on it. $3.00 1 set of stock carb pilot jets 25 Free 1 set of stock carb main jets 320 Free Throw me $80.00 take it all or we play the piece meal game. All items are shipped USPS with photo receipt sent as proof. Just want these things gone. 717-675-4472 Edited June 9, 2016 by Oldskool83 Quote Link to comment Share on other sites More sharing options...
