Banshee will only spark when push started
You need to get next to a known good banshee and start swapping parts. CDI's are generally all or nothing but I have seen some crazy stuff like this one time. Ended parts swapping with bhatch21 and eventually the Cdi was the problem.
I just had the same thing happen with mine and it was the CDI.  Had good compression, stator ohmed out fine, pickup coil gap was in spec.  Replaced the wiring harness with a new one, replaced the coil.  In the end, it was the CDI for me.  I bought a procom from JDS Customs as it was much cheaper than factory OEM and I wasn't sure what the problem was.
