Please help pancake bearing issue !
So my clutch rod and ball and actuator were all welded, split the case replaced with all new components new rod,ball and clutch arm, seals etc purchased a pancake bearing so it won't happen again, installed new clutch cable went to adjust and it doesn't seem to line up anyone see anything wrong? Tried the small and big adjuster that came with bearing clutch is lined up right
As well as Torqued properly but the arrows won't line up
Small adjuster. Loosen everything on the perch. Now set the adjuster so the plate just starts to disengage when you pull the actuator past the arrow on the top case mark. It should line up when you just take the slack out by hand. Then hook up the cable and adjust it so the clutch lever has just a touch of play in and out. Like 1/8-1/4"
To clear all the confusing sorry guys lol
Factory clutch except for tusk clutch material and metal
Cascade pancake bearing currently have short rod in. This is the rod to use?
So to adjust unhook clutch cable on handle bars from lever, pull arm toward clutch side adjust till it lines up?
Then connect cable and fine tune it??
Yes use short rod...unhook cable pull lever toward the clutch side adjust to arrow on case and fine tune on lever..lever should have 1/8 to 1/4 in of play..
Sent from my VS810PP using Tapatalk
Ok I think I got it tell me Whatchall think!
Adjusted without cable attached I left it alittle to the left side (on left side by stator) then fine tuned it up top
Yup sounds good pull clutch lever and see if it engages
