darkness878 Posted May 18, 2016 Report Share Posted May 18, 2016 So my clutch rod and ball and actuator were all welded, split the case replaced with all new components new rod,ball and clutch arm, seals etc purchased a pancake bearing so it won't happen again, installed new clutch cable went to adjust and it doesn't seem to line up anyone see anything wrong? Tried the small and big adjuster that came with bearing clutch is lined up right As well as Torqued properly but the arrows won't line up Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted May 18, 2016 Report Share Posted May 18, 2016 Small adjuster. Loosen everything on the perch. Now set the adjuster so the plate just starts to disengage when you pull the actuator past the arrow on the top case mark. It should line up when you just take the slack out by hand. Then hook up the cable and adjust it so the clutch lever has just a touch of play in and out. Like 1/8-1/4" Quote Link to comment Share on other sites More sharing options...
darkness878 Posted May 18, 2016 Author Report Share Posted May 18, 2016 so unhook it from the arm itself adjust from clutch side? set it that way with it alittle past the arrow on stator side of case then attach cable and fine tune it on level? Quote Link to comment Share on other sites More sharing options...
darkness878 Posted May 18, 2016 Author Report Share Posted May 18, 2016 i have the cascade kit comes with 2 sized rods big or small? Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted May 18, 2016 Report Share Posted May 18, 2016 I can't follow any of that above. With the cable loose at the perch on the handlebars, Hold the actuator lever towards the right with your thumb while adjusting the pancake until the arrows line up. Quote Link to comment Share on other sites More sharing options...
Shee_fast Posted May 18, 2016 Report Share Posted May 18, 2016 i have the cascade kit comes with 2 sized rods big or small?If running a 7 plate setup use the short rod Sent from my VS810PP using Tapatalk Quote Link to comment Share on other sites More sharing options...
darkness878 Posted May 18, 2016 Author Report Share Posted May 18, 2016 To clear all the confusing sorry guys lol Factory clutch except for tusk clutch material and metal Cascade pancake bearing currently have short rod in. This is the rod to use? So to adjust unhook clutch cable on handle bars from lever, pull arm toward clutch side adjust till it lines up? Then connect cable and fine tune it?? Quote Link to comment Share on other sites More sharing options...
Shee_fast Posted May 18, 2016 Report Share Posted May 18, 2016 To clear all the confusing sorry guys lol Factory clutch except for tusk clutch material and metal Cascade pancake bearing currently have short rod in. This is the rod to use? So to adjust unhook clutch cable on handle bars from lever, pull arm toward clutch side adjust till it lines up? Then connect cable and fine tune it?? Yes use short rod...unhook cable pull lever toward the clutch side adjust to arrow on case and fine tune on lever..lever should have 1/8 to 1/4 in of play.. Sent from my VS810PP using Tapatalk Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted May 18, 2016 Report Share Posted May 18, 2016 I dont even use the arrow on the cases. I just make sure i have a little slack on the clutch lever. I've got a slingshot and cascade pancake bearing so the arrows are useless to me. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted May 18, 2016 Report Share Posted May 18, 2016 I dont even use the arrow on the cases. I just make sure i have a little slack on the clutch lever. I've got a slingshot and cascade pancake bearing so the arrows are useless to me.Hmmm, mine line up. Quote Link to comment Share on other sites More sharing options...
darkness878 Posted May 19, 2016 Author Report Share Posted May 19, 2016 Ok I think I got it tell me Whatchall think! Adjusted without cable attached I left it alittle to the left side (on left side by stator) then fine tuned it up top Quote Link to comment Share on other sites More sharing options...
Shee_fast Posted May 19, 2016 Report Share Posted May 19, 2016 Ok I think I got it tell me Whatchall think! Adjusted without cable attached I left it alittle to the left side (on left side by stator) then fine tuned it up top Yup sounds good pull clutch lever and see if it engages Sent from my VS810PP using Tapatalk Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted May 19, 2016 Report Share Posted May 19, 2016 Just make sure there is play in the lever. If you use tension on the cable to pull the actuator arm forward, that acts just like you squeezing the lever so the clutch will never be fully engaged. It will slip the clutch. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted May 19, 2016 Report Share Posted May 19, 2016 A touch one way or another on the case mark adjustment isn't bad. It's just a gauge so you can get a decent amount of clutch throw. If you are drag racing you can do some interesting things with that adjustment. Quote Link to comment Share on other sites More sharing options...
