trickedcarbine Posted June 8, 2016 Author Report Share Posted June 8, 2016 That's dope, Rodger and I were talking about trying the Oval, but he was a bit hesitant. I suppose it's worth a shot if it's lighter then this heavy ass Roll swinger. Quote Link to comment Share on other sites More sharing options...
bigweav81 Posted June 8, 2016 Report Share Posted June 8, 2016 From Palmdale? Sent from my iPhone using Tapatalk This your bike tricked? Sent from my SM-S820L using Tapatalk Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted June 8, 2016 Author Report Share Posted June 8, 2016 This your bike tricked? Sent from my SM-S820L using Tapatalk Just another frame and a bunch of light weight chromoly in the box. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted June 8, 2016 Report Share Posted June 8, 2016 That's dope, Rodger and I were talking about trying the Oval, but he was a bit hesitant. I suppose it's worth a shot if it's lighter then this heavy ass Roll swinger.What's up with that heavy ass roll arm Quote Link to comment Share on other sites More sharing options...
bigweav81 Posted June 8, 2016 Report Share Posted June 8, 2016 I see. It would be cool if you start a build thread when figured out, and assembling. Sent from my SM-S820L using Tapatalk Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted June 8, 2016 Author Report Share Posted June 8, 2016 What's up with that heavy ass roll arm 300 shipped? Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted June 8, 2016 Author Report Share Posted June 8, 2016 I see. It would be cool if you start a build thread when figured out, and assembling. Sent from my SM-S820L using Tapatalk once I pop the clutch on the frame. Quote Link to comment Share on other sites More sharing options...
bigweav81 Posted June 8, 2016 Report Share Posted June 8, 2016 Hell yeah. Not trying to derail the carbon fiber talk. I'm just trying to learn about all set ups. I'll be waiting. Sent from my SM-S820L using Tapatalk Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted June 8, 2016 Report Share Posted June 8, 2016 Is this a MX bike or what? Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted June 8, 2016 Report Share Posted June 8, 2016 SB07 Here's the arms. You can't really tell the differences. Sent from my iPhone using Tapatalk I'm assuming that the heims mount inside of the factory located tabs? If so, ditch all that center nonsense and run a Ti bolt on each side. That spacer is not needed IMO. Edit. I looked at pic again. Why not build those so that the heims bolt to the inside of the factory outside tab? Cut the inside tabs off (or build without them) and be done? Why do you need the misalignment tapered spacers? All that thing is doing is going up and down. With that you loose the long bolt and replace with 2 bolts and 2 nuts, and you loose 4 of the tapered spacers and that big middle spacer. Sent from my SCH-I545 using Tapatalk Quote Link to comment Share on other sites More sharing options...
JTmachining Posted June 8, 2016 Report Share Posted June 8, 2016 That's dope, Rodger and I were talking about trying the Oval, but he was a bit hesitant.All the swingarms are aero tube. -4 to +14 etc Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted June 8, 2016 Author Report Share Posted June 8, 2016 Is this a MX bike or what?TT/flat track Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted June 8, 2016 Author Report Share Posted June 8, 2016 I'm assuming that the heims mount inside of the factory located tabs? If so, ditch all that center nonsense and run a Ti bolt on each side. That spacer is not needed IMO. Edit. I looked at pic again. Why not build those so that the heims bolt to the inside of the factory outside tab? Cut the inside tabs off (or build without them) and be done? Why do you need the misalignment tapered spacers? All that thing is doing is going up and down. With that you loose the long bolt and replace with 2 bolts and 2 nuts, and you loose 4 of the tapered spacers and that big middle spacer. Worth looking in to. Thank you sir Sent from my SCH-I545 using Tapatalk Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted June 8, 2016 Report Share Posted June 8, 2016 Yea. No jumps = ti swingarm. That will be your greatest weight savings. Half the weight of chromoly for sure. Quote Link to comment Share on other sites More sharing options...
JTmachining Posted June 8, 2016 Report Share Posted June 8, 2016 But chromoly is super light weight......It is. U are learning Quote Link to comment Share on other sites More sharing options...
