JTmachining Posted June 8, 2016 Report Share Posted June 8, 2016 But it really isn't. You still have a lot to learn.Post up light weight parts you have designed and made. Till then you are and always will be just a google keyboard racer with this subject Quote Link to comment Share on other sites More sharing options...
JTmachining Posted June 8, 2016 Report Share Posted June 8, 2016 Material component to application choice and quality are super important. Strength and weight per application is a big factor. These are just some basics that are known and would think anyone discussing anything technical pertaining to this would know, remember, and not post up stupid shit with this said. Peeps obviously do not know this and don't factor this into discussions or even design to making light components. I see why peeps here on BHQ make train wrecks out of good threads...cause they have no clues Zilla stop deflecting. U have no experience in the subject and just calling u out on BS Quote Link to comment Share on other sites More sharing options...
JTmachining Posted June 8, 2016 Report Share Posted June 8, 2016 How much weight can be removed from Mattoon cases? Or a complete motor setup? No one makes over sized plastic bowls do they?Ask Zilla Quote Link to comment Share on other sites More sharing options...
JTmachining Posted June 8, 2016 Report Share Posted June 8, 2016 So again, what is that about strength versus weight?Here's a clue. Diff tube diameter and wall thickness have diff weights and strengths. Not gona waste any more time trying to correct u. Others can decide to use ur copy and pasted info and BS or not Quote Link to comment Share on other sites More sharing options...
JTmachining Posted June 8, 2016 Report Share Posted June 8, 2016 Lol Zilla u really don't have any clues Quote Link to comment Share on other sites More sharing options...
JTmachining Posted June 8, 2016 Report Share Posted June 8, 2016 What about running a PVL, that'd reduce some weight wouldn't it? Could also do a starter box etc etc.. This may be all drag shit, dunno about the PVL though, never seen someone run one other than drag.Ask Zilla Quote Link to comment Share on other sites More sharing options...
JTmachining Posted June 8, 2016 Report Share Posted June 8, 2016 Should, because we all know you have no clue about flywheel weight and how the weights effect engine performance. As for making an engine lighter, there are many ways to shave an ounce here or there, issue is it isn't cheap. As for billet aluminum cases, why not make a light weight chomoly set of cases. After all, you can make it light weight. Post up pics of what u have done to make it all lighter. I can of all of this and post facts Quote Link to comment Share on other sites More sharing options...
JTmachining Posted June 8, 2016 Report Share Posted June 8, 2016 Knowledge isn't free and u can't buy clues Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted June 8, 2016 Author Report Share Posted June 8, 2016 Doesn't hurt to call and ask. Regardless, theres still builders who will make this stuff if you have money. The answer was no Quote Link to comment Share on other sites More sharing options...
JTmachining Posted June 8, 2016 Report Share Posted June 8, 2016 The answer was noThe less material used the less of a diff there is from chromoly to titanium. Jus something to keep in mind Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted June 8, 2016 Author Report Share Posted June 8, 2016 Yessir Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted June 8, 2016 Report Share Posted June 8, 2016 With carbon pipe clamps, and Ti hardware. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted June 8, 2016 Report Share Posted June 8, 2016 I think before anything CF should be used, have readily available titanium parts built or acquired. If it's not being jumped, ti arms and swingarm will net you close to 10 pounds in savings alone. Then, there are other things, like JT Machining carrier lightening. Then, aluminum bolts.. In my honest, somewhat experienced opinion, CF is nearly pointless with all the titanium possibilities and other light weight parts. Quote Link to comment Share on other sites More sharing options...
J-Madd Posted June 8, 2016 Report Share Posted June 8, 2016 Just build chassis out of this. It weighs nothing. Problem solved! Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted June 8, 2016 Report Share Posted June 8, 2016 If you're not starting with at least a full chromoly chassis, the rest is just pointless, especially when talking about CF. Quote Link to comment Share on other sites More sharing options...
