ClaudeMachining Posted May 13, 2016 Report Share Posted May 13, 2016 This is where i am so far.... Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted May 13, 2016 Author Report Share Posted May 13, 2016 How smooth the surface have to be? Quote Link to comment Share on other sites More sharing options...
Tedder Posted May 13, 2016 Report Share Posted May 13, 2016 The best porter I ever knew said it should be like a cats tongue. 2 Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted May 13, 2016 Report Share Posted May 13, 2016 You want it gritty and textured. All that nonsense about polished ports from the 60's & 70's has been de bunked. 1 Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted May 13, 2016 Report Share Posted May 13, 2016 Bead blast it Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted May 13, 2016 Author Report Share Posted May 13, 2016 Job done. I could get some.more material, but i want a little bit of a safe margin. Quote Link to comment Share on other sites More sharing options...
Surfrjag Posted May 13, 2016 Report Share Posted May 13, 2016 How well does the gasket match the cyl. Matches case great 1 Quote Link to comment Share on other sites More sharing options...
guns4children Posted May 13, 2016 Report Share Posted May 13, 2016 Stock head on your new build? Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted May 14, 2016 Author Report Share Posted May 14, 2016 Stock head on your new build?No, driveline lp ported by Bill. Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted May 14, 2016 Author Report Share Posted May 14, 2016 Will work a little bit on the transition. Quote Link to comment Share on other sites More sharing options...
bigweav81 Posted May 14, 2016 Report Share Posted May 14, 2016 Decent. Sent from my SM-S820L using Tapatalk Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted May 14, 2016 Author Report Share Posted May 14, 2016 How well does the gasket match the cyl. Matches case greatBill did the matching of the gaskett/cyl. It match great too. Envoyé de mon GT-P5113 en utilisant Tapatalk Quote Link to comment Share on other sites More sharing options...
vrx46 Posted May 14, 2016 Report Share Posted May 14, 2016 Gonna attempt this sometime this week Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted May 14, 2016 Author Report Share Posted May 14, 2016 Gonna attempt this sometime this weekI will do the finishing touch monday. I did it with a dremel. I first make a chamfer, close to my line, then did the vertical part to match the chamfer. I will remove a little more material at a couple of place and smoth the transition between the old and the 'new' porting. Envoyé de mon GT-P5113 en utilisant Tapatalk Quote Link to comment Share on other sites More sharing options...
Shee_fast Posted May 15, 2016 Report Share Posted May 15, 2016 What does this accomplish...yes this a real question I've heard of it but what's the exact reason..same as porting cylinders? Sent from my VS810PP using Tapatalk Quote Link to comment Share on other sites More sharing options...
