doug Posted May 10, 2016 Report Posted May 10, 2016 Hi - What are you guys using to clean your air filter and outwear? I'm having no luck with dish soap. This stuff is sticky. Thanks. Quote
sheerider11 Posted May 10, 2016 Report Posted May 10, 2016 I use simple green. I fill a little tote drop them in. Let them sit for a few hours. Water is warm to. Quote
trickedcarbine Posted May 10, 2016 Report Posted May 10, 2016 That^. If I'm in a pinch, simple green ain't bad. Just takes more effort. Sent from my iPhone using Tapatalk 1 Quote
doug Posted May 11, 2016 Author Report Posted May 11, 2016 Thanks guys - off to Canadian TIre I go! 1 Quote
jbooker82 Posted May 16, 2016 Report Posted May 16, 2016 I uses the same brand cleaner as the oil used. Who would of though a company developed a cleaner to remove their air filter oil. Quote
sheerider11 Posted May 16, 2016 Report Posted May 16, 2016 I Use The Maxima Fab 1 Spray On. A little trick I learned from WCJ was stick a vacuum in it and spray. Sucks the spray right in to the pleats and minimal over spray Quote
ClutchLuck24/7 Posted January 9, 2017 Report Posted January 9, 2017 I Use The Maxima Fab 1 Spray On. A little trick I learned from WCJ was stick a vacuum in it and spray. Sucks the spray right in to the pleats and minimal over spray +1 On the Maxima stuff.. They sell their oil and cleaner in a kit also if you wanted to go that route Quote
doug Posted April 30, 2017 Author Report Posted April 30, 2017 In follow up to this, I used "Super Clean" from Canadian Tire. It said that it dissolves grease. I would not recommend it and will be trying a different product. Quote
