LED Cube Headlights
Make a search about LED lights first, you will find plenty of setup.
I've done plenty of searching but I haven't found what I'm looking for, i'm going to send me bike to powdercoat but before I do I want to know if I should cut the stock light mounts in order to run the cubes, I'm trying not to cut them and not sure whether or not someone makes a bracket to fit them in the original spot.
I'll post when I get home if I remember. Someone fabbed me some mounts so it works with stock mounts on the frame. I don't like the idea of removing stock headlight mounts.
If someone could cnc a pair in the $20-$30 to work with stock mounts, they would do well.
I don't want to cut the factory mounts just because once they are cut theres no going back
Baja designs squadron pros mounted on trail tech mounts.
Electrical:
DC conversion
200 watt Gary Tator salad stator
Trail tech battery (3700mah)
Podtronics rectifier
dbd773baf9ec2424a318b093be95e6e3.jpg49ca2bf1d54eac2d950d16a10796b44b.jpgef38ffa462c6f7ea29a651a33a9cd2ae.jpg
Anyone on here run LED Cube headlights like the Rigid Industry D2 HD? If anyone can post pictures of their bikes and show me how they mounted theirs it would be greatly appreciated
I will post mine.
