Trx450r Posted May 4, 2016 Report Share Posted May 4, 2016 (edited) FIRST OFF, SORRY! THIS IS FOR A HONDA, BUT HONDA FORUM IS DEAD A.F. My brother is the banshee Here is my 'issue' I need to win my brother in ALL of the races.Right now, our races consist of two main areas.Ill do my best to explain it for you guys.Race 1: Is a 800-900 ft race that's pretty steep, but its longer, and less steep then race 2, lasting about 25-30 seconds.Race 2: Is about 700 ft and significantly steeper, the races last about 20 seconds.I beat my brother all day long in Race 1 @ the top of third gear I'd say about 85-95% @ the top, just under the rev limiter. I pull on him from bottom, to top of the hill.Race #2 is where I lose. I beat him up until about 3/4 of the hill, then he pulls on me [video @ bottom shows this at 2:50 ish]. I can do the 2nd race in 3rd gear, but I'm about half way to the power band (which is just under rev limiter) and I go faster in 2nd gear, but I'm ON the rev limiter almost the whole time.Now... Here's where I need the help.What should I do with my sprockets to get me as close to the power band for each race.Lower rear sprocket and make third gear smaller, essentially?Raise rear sprocket and make second gear larger?Cut my losses and deal with it?https://www.youtube.com/watch?v=GngQmRnVReM Edited May 4, 2016 by Trx450r Quote Link to comment Share on other sites More sharing options...
JTmachining Posted May 4, 2016 Report Share Posted May 4, 2016 Buy a Banshee 3 Quote Link to comment Share on other sites More sharing options...
Trx450r Posted May 4, 2016 Author Report Share Posted May 4, 2016 Buy a Banshee Do they make them small enough to fit on my honda? 1 Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted May 4, 2016 Report Share Posted May 4, 2016 So, let me get this right. You want a Banshee forum help a Honda beat a Banshee? If you drop one tooth on the rear, it would help second gear in race two, but might kill you in first race. Not knowing how the ratios are in the trans no way to suggest gearing way the fuck down and using 3-4 gears. Might be time to add more powwaazzz. 3 Quote Link to comment Share on other sites More sharing options...
Trx450r Posted May 4, 2016 Author Report Share Posted May 4, 2016 So, let me get this right. You want a Banshee forum help a Honda beat a Banshee? If you drop one tooth on the rear, it would help second gear in race two, but might kill you in first race. Not knowing how the ratios are in the trans no way to suggest gearing way the fuck down and using 3-4 gears. Might be time to add more powwaazzz. I came to an active forum, hoping for some helpful advice. Everyone likes to win right? Thanks for your reply We can pretend I'm a banshee Quote Link to comment Share on other sites More sharing options...
