Jetts on banshee
Have CPI pipes on my 2005 banshee, and k&n air filter. What size jetts and needles should I install?
You need to list all the info. Asl, temp, size of carbs, and all mods.
Sent from my SM-S820L using Tapatalk
  • 4 weeks later...
Can anybody help I need to know the distance before I have to board my cylinder how much space can I have between the piston and the cylinder wall on a stock banshee with a forged piston
Sent from my XT1254 using Tapatalk
Learn the terms first !!
You're asking what the clearance should be to have the cylinder bored ??
If your machinist doesn't know , find a different one.
HINT : it's less than an average human hair.
the least you can do is hone the cylinder walls and wash them very good. Install the same Pistons with new rings. After the top end do a leak down test to see if the crank seals are still good. Sometimes the intake boots are prone to leaks. Not good will lean it out if seals are bad. Good luck.
