Larry's Shee Posted April 25, 2016 Report Share Posted April 25, 2016 Bowl for left/choke carb has a little "BB" on bottom front of bowl. How are reeds? Sit tight? No frays,chips, cracks ? What size pilots? Any porting? Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted April 25, 2016 Report Share Posted April 25, 2016 What was this shop supposed to fix? Quote Link to comment Share on other sites More sharing options...
Lowroll Posted April 25, 2016 Report Share Posted April 25, 2016 Op, are you in Richmond VA? Sent from my SM-N910V using Tapatalk Quote Link to comment Share on other sites More sharing options...
Deezy804 Posted April 26, 2016 Author Report Share Posted April 26, 2016 So it ended up being something with the kick start , u have to have it down near touching the foot peg before u stomp it fired right up tho smh Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted April 26, 2016 Report Share Posted April 26, 2016 You took it back to that shop and really have no idea what they did, huh? Quote Link to comment Share on other sites More sharing options...
Deezy804 Posted May 2, 2016 Author Report Share Posted May 2, 2016 I know exactly what he did or was supposed to do Shiit just felt different after what he was claiming to have fixed Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted May 2, 2016 Report Share Posted May 2, 2016 Infamous mechanic Ben Dover strikes again. Quote Link to comment Share on other sites More sharing options...
guns4children Posted May 2, 2016 Report Share Posted May 2, 2016 You do know you can adjust the kicker right? Quote Link to comment Share on other sites More sharing options...
kawa110 Posted May 2, 2016 Report Share Posted May 2, 2016 Most likely sat at shop, sat around before shop, with gas in it......clean the carbs...at same time verify the bowls are on correct...put fresh gas..... Let's see pictures of the "lines running to carbs"....most likely added carb drain hoses to make you feel like ther was lots of work done Quote Link to comment Share on other sites More sharing options...
